What are the dimentions for wheels that would fit on the 9000 aero? i looked on my usual tirerack.com and it would not allow me to browse wheels..
Thanks,
Ryan
4 X 108. Wheels in that size for Saabs are very hard to come by. Not too many companies made wheels that size.
What are you looking to put on? 16s, 17s?
You ideally need something with a 4x108 bolt pattern, 65.1mm hub bore and realistically no wider then 7.5".
I run 17x7.5" et35 w/no spacers on my 95 Aero w/225/45/17 tires. Clearances are tight.
Check out the audi forums. Alot of early audis used this lug pattern and can be made to work by using a grinder on the center bore or hubcentric adapters. Early ford mustangs had the same pattern as well. The factory offset for 9000 aeros was around 27mm for reference.
