Hello guys, I have a '93 900 S 2.1 with running/idling issues. On cold start it starts and idles normally but after hard driving, or highway driving it will have an erratic idle and sometimes die completely. The issue doesn't come up on steady state cruising and I've driven for hours on the highway with no issue, but when I slow down for an onramp or exit ramp it will turn on the check engine light, burble and rev erratically and then usually idle at an extremely low speed, under 500 RPM, then die completely.
I've cleaned and tested the air mass meter , tested the ELCD valve for resistance (charcoal canister), replaced and tested the o2 sensor and preheater circuit, checked the coolant temp sensor for resistance, and used carb cleaner to check for vacuum leaks and found none. I pulled a vacuum hose while running and while it did idle worse, it still idled, leading me to believe a vacuum leak wouldn't cause the issue I'm having.
I've also pulled several check engine codes: 12223: AFR too lean, 12241: AFR fault, 12111 and 12112: Oxygen sensor self-compensating circuit problem (12111 means incorrect AFR while driving and 12112 means incorrect AFR at idle)
Today, I pulled the coolant temp sensor plug and drove it hard hoping to see if the issue wouldn't appear without the sensor, but I had the same problem with it dying at stop signs, and while parking.
Does anyone have any other suggestions or experience with this issue? I'd really appreciate any and all suggestions and help.
