1 - 7 of 7 Posts
I HAVE A 1991 saab 900 non turbo 16 valve. Would the axles from a 1989 saab 16 valve non turbo fit my 91? My 1989 was manufactured August 1989, so is this car really a 1989 or a 1990? I was told that if a car was manufacured on certain months within a year, the car could have been technically concidered a 1 year later model than the sticker date on the drivers door. My question is: Which month does this "next year technicality" become valid in referance to manufacturer door stickers? I know that the "inner drivers" are compatible, but the "drive axles" are iffy....
it's basically model year generally as from the VIN digit
What is important in your case is ABS or not ABS, there is a ring on the axle. You can heat the ring and remove it from a '91 axle and put it on an '89 axle and use that, in fact I did exactly that on my convertible last year. It is too much work if you can get a '90+ for the same price however.
what ring?
what ring exactly do i heat up?
There is a ring on the wheel end for the ABS sensor. If you look at both axles you'll see one has it and the other not.
1 - 7 of 7 Posts
