1 - 9 of 9 Posts
It looks like my alarm fob is broken and my car is stuck out on the street! I was wondering if there is a relatively easy way i can disable the alarm so I can atleast move my car before I have it looked at?
Im not sure if it is an aftermarket alarm/immobiliser or not. Il take a photo of the fob when i get home.
I have tried disconnecting the battery for atleast 30 mins but that has not worked.
Any ideas?
Cheers,
Ingy
I am not sure about other markets but U.S. Market 9000's didn't have keyless entry till 1995. Mine is a 1994 and I was horribly distraught when I found out I couldn't have a keyless. I'm thinking it must be aftermarket in which case you would probably have to contact the alarm manufacturer about emergency disabling procedures.
Ah damn. There are no markings on the fob itself apart from what seems to be a model number (ZTX-D2). Ive googled it but cannot find anything.
Would there be anything in/on the car that may point me in the right direction?
Do a search on Ebay motors for Saab 9000 there is usually a few factory key fobs on there that you could look at to compare with yours. As far as I know there is only 2 buttons on the factory key fob, one with a key imprint that is for locking/unlocking, and another for opening the hatch.
Edit: This is the '95-'98 Key fob.
mine is a woodgrain brown colour with only one button. Il post a picture, it may make it easier.
Super Moderator EMERITUS
Sounds kind of similar to the ZVS-250 I had in the old 900. I tracked the maker down to an outfit called Zylux in Melbourne. Mine was just out of frequency range and they sorted that for me. I don't see your model number amongst theirs though. If you can find the alarm module, that would help.
Yea I can't see it there either and they don't have a page where you can look at their older models..
Where would I find the alarm module? (Sorry I'm a bit of a novice..)
In your case it might be wiser to get an alarm tech to sort it out. They should just come out and dial in a new remote for you. The remote has to be adjusted to the frequency of the module, and possibly the module reset anyway. So you can't just buy a new remote and expect it to work right away. Yeah, best get a tech out to do it.
I suppose you've tried new batteries in it?;)
Yea I did try new batteries.
Good idea about the alarm tech, didn't even think about that. I was going to get roadside assist out but i dont think there will be much they can do.
Will have to try and find one that will come out in adelaide.
1 - 9 of 9 Posts
