Hello
Just picked up a 89900 turbo convertible
Previous owner said it died on his way home. He could get it to run when jumping the fuses
When I checked the car out it did crank over.
We hauled it home on a flat car hauler trailer
Now I cannot get it to crank over to start diagnostics on the no start issue.
The key seems pretty loose. Hard to tell when you go past ignition and on to start position.
In what o think is ignition spot the battery light comes on and move it the key a bit more clockwise the check engine light comes on. I do get a rely click above the ecu and one in the fields box.
Lights and other features work
Acts like an open switch or immobilized somehow.
I’ve tried moving the shifter around in both park and neutral with no luck.
Any thoughts where to look on getting it to turn over?
Thanks
Thanks
