Now that the weather is not insanely cold, I am starting work on my 86 SPG.
1st on the list is prepping a good transmission.
The original has a tooth missing from the ring gear.
The roll pin on the shift selector rod came out, and broke the gear. All other gears appear good. Transmissions are a weak area for me, so hopefully I will be able to replace the gear successfully. I have several extra 5 speeds with varying problems, but I do have a good diff from an 87 that had a cracked transfer case.....let the suffering begin.....
