Problem:
Hello again and thank you to anyone who can lend me assistance in this mystery. 1986 900 Turbo. Drove the car and all ran well. Parked the car for 4 days. Came out to drive the car and the car will only crank.
My non expert diagnostics:
Spark plug test light in between the plug and wire indicates no spark.
Test light hooked to the negative on the battery with key on indicates solid power on both coil posts as well as with engine cranking.
My conclusion and Fix:
I replaced the ignition control module tonight and the car will not start.
Not sure how to make it run again????!!!!!?????
HELP!!!!!
Most likely point to start with is the distributor.
This "might" help.......
