I figured I was long past due for a dedicated project thread and rather than keep filling up other threads with my questions I'm just going to post them all here. Alright so first off, a little history on the car.
I bought my Saab in late May of 2007 from a neighbor/family friend for $800. It has about 308,000mi so it's up there. If anyone is curious why I've named the car Saabuffet it's because I find the car looks similar (at least color-wise) to Wobbuffet (it's a Pokemon. Remember those days? haha) Here are some pics of how it looked when I first bought it:
I wish this statement were true, but I haven't had A/C since I've owned it. :cheesy:
As far as I knew the only problem with it at the time was the power steering, but after browsing this site for a bit I learned that most likely there are more problems than you may think. :lol: So once the car was officially mine and at my house I've since then:
changed the oil
installed new oil filter
added a power steering belt (since it didn't have one)
put in a new air filter
changed the front passenger side brake caliper and hose (old caliper was leaking)
bled the brakes
installed a new oil pressure switch since the old one was leaking
put in a heavy duty skid plate
installed a refurbished power steering rack and new outer tie-rod ends (thanks to the help of you guys
If you have read on the "questions you think are too stupid to ask" thread lately you would know that I had quite a few issues with the power steering rack. The most annoying being that I couldn't put one of the bolts that bolt the rack to the body back in. When I took in my car over to Scanwest Autosport for a front-end alignment and a safety inspection on December 2 they were able to put the original bolt back in for me.
It also turns out to be a good thing I did the safety inspection because they found a few problems. First off my driver's side ball joint was really bad and a real safety issue. other things they noted was my clutch hose was leaking and my lower control arm on the drivers side was cracked. Luckily I had bought a new lower control arm a while ago so I just had them put that one on. Anyway those were the things they replaced.
Alright I know this is a project thread and I haven't really posted any real projects yet but I have a list from the safety inspection of things they found but didn't replace for me (good, I want to do as much of my own work as I can!) A lot of it are minor things but here is what they put:
Centralizing spring is broken
Header pipe bracket is broken
Oil pump is leaking and main pulley is bad
Headgasket is leaking externally
Both left upper a-arm bushings are failing
Muffler is failing inside (I saw a couple small holes where it would leak)
Elbow hose for the fuel rail needs to be updated
So I need to ask, what do you think should be tackled first? Maybe you can rearrange the order I should do these tasks and then I'll upload pics of me doing them when I get to them.
changed the oil
bled the brakes
