CAR: 1984 4 door SAAB 900 FI
hi all, i am new to the community here i have done some searching multiuple time without reallly finding anything that i could use towards my issue, just some that may be falling under the umbrella or what ifs.
to start i dont really know a whole to lot about the saab motors themselves. i was a mechanic for two years and decided to go somewhere else at the time, i dont mind doing the work and know atleast what im looking at and can do..
the 1984 saab 900 i picked up about a month ago and when i bought it, it did have a idle issue but thought we had gotten it sorted out with the set screw behind the carb. i got it to where the vehicle would start by its self it was always intermittently starting with the key. sometime i would push the pedal to the floor to disengage the fuel injector and it would start..
about a week ago i went to start the vehicle. it cranked a few times, tried to start, and it backfired through the carb.. up until this point the vehicle was able to start on its own ( without starting fluid) when it backfired i put everything back together, the tubing had just came apart from my throttle body to carb. so i put it back and tried to get it started.. it wouldnt start so i rolled it down the hill and dropped the clutch and got it going, the vehicle ran very rough, when i would give it gas, it would die down a bit. ( kinda like it was flooding) then it would go away after i ran it about 3k rpm for a minute..
the only way i can get the vehicle started now is with starter fluid, i have about a half a tank of gas, once its started, i cant let it drop under about 1500 RPM otherwise it dies. once it dies, starting fluid is needed again. even though once started will stay started untill it drops to about 1500rpm it starts running rough shakes then will die if i let it.. being as this is a issue its driveable i had to drive about 10 minutes from my house to get internet from my parents, so as you could imagine a lot of heel toe was used to not the let vehicle die while comming up to stop lights and intersections..
my first though would be my gas tank/fuel filter?? maybe i have rust in my tank, or the filter is dirty. im not 100% though.. it would be greatly appreciated if anyone could help me out, any pointers or anything.
Thanks in advance
Thanks in advance
