O.K. I have been messing around trying to get this electronic water pump (http://www.geocities.com/saab99ewp/) installed into my wife's 1979 Saab 99. And for never working on a Saab before I think I am doing all right.
The car was quite dismantled and now has since then been put back together almost all the way... I was to test the EWP out but I first need to get everything back together and I have a few small issues I need to take care of first. So please bear with me here because I took some pictures that I need help with.
I hope all goes well from this point. Ready - here we go:
1. I am not sure if I have the correct hose going to this nipple that is located on the "U" shaped tube. It looks as if the hose came from underniether the air filter area but I am unsure. I need a thumbs up or thumbs down on this.
2. I don't know what hose connects to this.... and if I don't have the hose I need to get one.
3. Not sure where this goes to... ;oops:
4. Once again.. I have a hose connected to this but I am not sure where the other end connects to... I assume it goes to the sensore that is located in the manifold that is against the block... am I right?
5. I don't know if this is a sensor on the alternatore or where it suppost to connect to... I have it cliped on the bolt where the white/grey wires bolt onto. (B+)
6. I do not have the "U" bracket that blocks the Fan blades to this... is this a no no :nono; ... or is just to keep fingers (or wires) out of it... Reason is... If I don't absolutely have to attach it back on... I think I will just leave it off.
