I had the same problem. I know some people sayto extend the bumpstops, and if it works for them that's fine, but it didn't work for me. If you do extend them, replace the existing screw with a longer one and pack some more washers on the end. The drawback is that bumpstops drop off on a regular basis anyway, so are probably not going to help much in the long term. And I don't recommend just ignoring the rub, as simultaneous rear punctures would not be conducive to good handling.
I got rub with 205/50/16 Super Aeros with Dunlop SP Sport 9000 tyres. What I did was change the rear suspension. It had a saggy ar5e anyway like most C900s after 14 years, so I bought Sachs Advantage sports dampers from
PFS and Ventura heavy duty turbo springs from
Eurocarparts. I live in a very rural area and drive on farm tracks a lot so I wanted it to be fairly rugged. The ride is very good - sharper handling, perfectly comfortable on long journeys and no more rub.
I know Garry did a write-up on this over on
900 Aero and if you do a
search on here you'll find several posts on it, most of them from me
Welcome to Saab Central
