1 - 2 of 2 Posts
Hi,
I have a problem with my icm1 radio and with panel with "nightpanel" button. Only one diode works on each and doesnt turn off when ignition is off, even when i lock the car.
What i did before it have worked, I removed cdplayer and placed an aftermarket radio, I used an optic loop. Aftermarket radio is connected to cigarette lighter(+ and -), yellow battery wire and blue-white wire to blue-white wire.
The only solution for now is to pull fuse nr 14. I have unplugged battery for almost 12 hours but it didn't fix. I have unplugged all wires from my aftermarker radio and it doesn't even turn off radio and nightpanel panel backlight. I have no idea what to do, maybe tech2 will help ?
1 - 2 of 2 Posts
