1 - 13 of 13 Posts
Hi,
BT on my wife's 09 combi worked just fine for about five months. All of a sudden, it would not hold pairing. I just paired her and my phones (two different models) and everything worked fine until the car was turned off and sat for a few hours. Then, when the car was turned back on, pairing with both phones was lost - The "Bluetooth - List" command returned "no paired devices", and I can't connect manually with either phone. However when I tried to re-establish pairing, it wouldn't let me use same device name tag as last time, so I assume the record of the paired device is still there and it's just a glitch in BT firmware.
So, what should I do, short of wasting a day at the dealership. Did anyone have the same problem, and do you have a solution ? Is it something that I could request assistance for via OnStar ? Is there a way to "reboot" the system short of disconnecting the battery ? Any help would be appreciated.
Hi,
In most of the cases is a problem in the cellphone settings.
When a cellphone is paired with the UHP unit (univelsal handsfree phone), in links paired devices, menu options, it is necessary to pair the phone as trusted device and save to make it functional in the next time.
in the options menu BT cell phone must be visible to all.
does not operate this way or bt options are not displayed in the SID, the BT unit is damaged and needs to be replaced by another one.
That's two phones, not one. And BT was indeed added to the Trusted devices on both. Or do you mean there's a setting in car's BT to add a trusted device ? I always used voice command "Bluetooth" -> "Pair".
if does not operate this way or bt options are not displayed in the SID, the BT unit is damaged and needs to be replaced by another one.
I don't recall BT options showing in SID. It woud show a phone icon, word "Bluetooth", or phone # when placing / receiving a call or saving a voice tag.
-trusted device in the cellphone not in the car.
I don't recall BT options showing in SID. It would show a phone icon, word "Bluetooth", or phone # when placing / receiving a call or saving a voice tag.
in the car:
check if blue-tooth is "ON" in the SID options (steering wheel button... options/telephone/blue-tooth:
enable/on or disable/off)
in the car:
I don't think I have a SID options menu. Are you talking about same steering wheel button used to set e.g. the climate control settings ?
BT altought being a ruled by specifications has issues, over the time I've noticed with various hardware (cell phones, handsfree, pc adapters and other hardware). The GM BT option does have compatibility, for example I have no problem with my old Motorola V360 while my wife Nokia's needs to be re-paired sometimes...
I would say:
1.-all phones OS symbian, sync, work but do not load the contacts, or last calls.
2.-phones nokia operating system (not symbian) version bt 2.0 work with almost everyone.
my tests:
nokia 6151 everything works. (bt 2.0, not symbian)
nokia 6680 and n80 synchronization but does not load contacts, no 'last call ..... (symbian).
UHP (universal hands free phone) specifications:
1 .- HFP 1.5 (Hands Free Profile (handsfree profile)
2.-bt compatible with 1.2 and above.
in short, not a matter of bt but symbian OS (operating system not working)
I think this will help
last year I wrote this in saabespaña.com
I heard that the operating system for sony bt, no problem with our cars, since they use the same blue-tooth chip technology.
however, the operating system symbian does not accept contacts, recent calls, it is the mobile brand.
I have three phones in memory synchronized (symbian-2 n6680, 1 n80), which took assets that bt is synchronized when entering the car, but contacts do not work .....
for me is enough without going over expenses ............ as leading not call anyone.
"I tested the base with an old phone (not symbian), but only supports the base and you can not memorize more phones ..........only one cellphone ......... catheter outdated one.
see pictures:
download compatibility cellphones
ADDITIONAL INFO MAILS FROM SAAB CUSTOMERS ATTENTION.
If you currently have a bluetooth enabled mobile phone, then this phone should be capable of being connected to the TEL4 without the installation of an additional kit is required.
For the following mobile phones can be ordered via parts & accessories additional operator, which connects the respective phone with the external antenna and acts as a charger for the battery. In addition to the devices listed below, there are other available Bluetooth phones, which are TEL4 compatibility. The full functionality is not guaranteed. The following phones are compatible TEL4:
- Motorola: E550, V600, V300, V400, V500, V525, V550, V620, V635
- Nokia: 3100, 6020, 6021, 6100, 6220, 6230, 6310, 6610, 6820, 7210, 7250, 6310i
- Siemens: C55, C65, C75, CX65, CX70, CX75, M55, M65, M75, S55, S65, S75, SP65
- Sonyericson: K700, T610, T630
We hope to have contributed to clarify the situation, and remain
Yours sincerely
Saab Germany GmbH
a second mail.........
Dear,
Thank you for your email dated 19 February 2008. We apologize for the unusually long processing time.
Regarding your request, we hereby inform you that the following mobile phones via Bluetooth handsfree is compatible with:
Nokia 6230 / 6230i
Nokia 6020/6021
Nokia 6310/6310i
Motorola V550, V600, V620, V635
SonyEricsson T610 / T630
SonyEricsson K750i, W800i, W810i, W700i
Siemens CX 75
Siemens S 75
In addition, the following mobile phones with a charger can be connected to the speakerphone on a cabling:
Phone number of the shell parts
Siemens S55 93 199 054
Siemens CX65 / M 65 93 199 564
Siemens S65 93 199 565
Siemens C65 93 199 566
Siemens C 75 93 199 381
Siemens CX 75 93 199 333
Siemens M 75 93 199 334
Siemens S 75 93 199 363
Nokia 6610 (7210, 7250) 93 199 063
Nokia 6100 93 199 061
Nokia 3100 93 199 060
Nokia 6230 / 6230i 93 199 058
Nokia 6220 93 199 062
Nokia 6820 93 199 059
Nokia 6020/6021 93 199 332
Nokia 6310/6310i 93 199 354
Nokia 6233 93 199 550
Nokia 6234 93 199 575
Nokia 6151 93 199 664
Motorola V300, V400, V500, V525, V550, E550, V600, V620, V635 93 199 053
SonyEricsson T610 / T630 93 199 057
SonyEricsson K700i 93 199 056
SonyEricsson K750i, W800i, W810i, W700i 93 199 543
Because of the various Bluetooth versions on the market, a full compatibility is not guaranteed. We therefore advise you to deal directly with a Saab dealer connection. The staff there will gladly give you the desired information.
For questions or suggestions, we are happy to continue and remain at your disposal
Yours sincerely
Saab Germany GmbH
Thank you for your e-mail dated 13 March 2007.
Regarding your request, we hereby inform you that the Saab 9-3 has TEL4. The new integrated phone (TEL4) replaces the current phone (TEL2) and offers the following advantages:
(1) there must be no additional SIM card is installed in the vehicle
(2) simplified operation of the phone book
(3) virtually all Bluetooth-enabled mobile phones can be connected to TEL4
(4) the telephone, and Voice Control can be operated via the steering wheel
For the following mobile phones can be ordered via parts & accessories additional operator, which connects the respective phone with the external antenna and acts as a charger for the battery. In addition to the devices listed below, there are other available Bluetooth phones, which are TEL4 kompartibel. The full functionality is not guaranteed. The following phones are compatible TEL4:
Yours sincerely
Saab Germany GmbH
As I heard about some posts in other forums, there is an update tech2 for the UHP - blue-tooth.
some comments (not confirmed by me) said about Version 3.0 and cost about 40€ to 70€. it depends of the dealer and city.
1 - 13 of 13 Posts
