What started as a P0303 (cylinder mis-fire #3) is not a car which will not stay started. I have 07 9-3, 76K miles. The car turns over, and will run for 30 seconds, then dies. I pulled out the spark plugs and noticed all cylinders are full of fuel. So it is definitely a issue with ignition, but it is effecting all cylinders. The weather is not best with plenty of snow and no garage.
Has anyone else had this problem? Any suggestions?
Could a MAP sensor cause this problem?
Is there another component upstrem of the coil which could cause this issue?
Thanks in advance.
Thanks in advance.
