1 - 7 of 7 Posts
Hi all,
I'm nearly stuck on my search for the cause of a mystery misfire in cylinder 1 of my 2007 Saab 9-3 Aero 2.8L Manual... My BlueDriver code reader is spitting out P0201 and P0301, and after replacing the cylinder 1 coil and plug, all the injectors, and performing countless tests, I have established the following:
Cylinder 1 is not getting any gas, despite having a new injector (injector is NOT clicking, and plug comes out dry)
Cylinder 1 is not firing, despite having a new coil and sparkplug (I do not have the tool to verify presence of a spark, but this coil and plug worked in another cylinder)
Injector 1 is getting 12V through the wire when the key is in the "on" position. I will try to test the ground wire today.
Cylinder 1 coil is getting 12V through wire when the key is in the "on" position. The other three wires give the same readout as for the wiring to the working coils. I will try to test the signal frequency to cylinder 1 today with the car running.
Any idea where to turn next? In my way of thinking, it has to be either a wiring problem between the coils and/or injectors and the ECU, or the ECU itself...
Thanks so much for the help! I have tons more info I could share, so ask any questions you think would shed more light on the situation...
Yes, ECU or wiring is bad. It's unusual that both injector and coil drive for one cylinder would fail in ECU. Wiring seems more likely.
Thanks! That sounds likely. The only reason I would wonder otherwise is that another website (not Saab specific) said the ECU might shut down an injector if it senses a misfire in that cylinder... not sure if this would throw an injector code though.
I'll see what I can do with the wiring today...
It occurs to me that it would be very helpful to know whether the coil/plug in cylinder 1 is actually sparking (duh... not sure why I didn't realize this earlier). I'll buy an inline tester later this morning and check it out. If I'm getting a spark there, the problem must be the wiring to the injector or the ECU not signaling the injector properly.
ECU would cut off an injector only as last resort to continuous misfires, if that's what you're getting.
Discussion Starter #6
Checked the spark today both at cylinder 1 and a few other good cylinders - all are sparking perfectly fine! Sooo… it's got to be some problem with the wiring to the injector, or the ECU, unless I'm missing something
Nope. Just don't forget to check connectors since they are also part of wiring.
1 - 7 of 7 Posts
