i have a 07 93 and yesterday the car started to blow cold air thro the vents wen temp was set to 22 and the temp in the car was only 12c-16c. it will only blow cold air if i select a temp other then the max heat than the car will blow hot air. i did try to reset the stepper motors with holding auto and recirculate buttons at the same time i felt the temp change but after it was finished its back to blowing cold air. did hock up my tech2 to see that the in car temp sensor is reading correct and it was reading 10c and colant was 80 but still blowing cold air even wen i am asking it for 27c. its the same for both vent sides anyone have a idea for what i can try next?
