Hi All,
I've been having this issue as of late. When the temperature is below freezing and I go to start my 06 9-7x it starts, then immediately turns itself off and throws a check engine light and a service Stabilitrak light.
A small caveat my steering wheel position sensor is going so this accounts for the service Stabilitrak when it gets cold, but the turning off of the engine is a new one and it has happened to me a few times while driving but only when it is below freezing outside. The engine shuts off, the electronics still work, and it'll let you coast to the side of the road.
I ran the check engine light and I'm getting a P0601 Transmission Control Module code, which after going through the service manual basically says there is an internal issue with my Powertrain Control Module and it needs to be replaced.
Has anyone had this happen? PCMs are usually fairly bulletproof and I'm curious whether the fact my steering wheel position sensor being on its last legs is throwing enough codes that creates the P0601 code in my PCM?
