1 - 7 of 7 Posts
Niece's 9-3SS ARC is having a audio freak out... It sets itself on max volume. If you reset it, it then will revert back to high volume after starting and using the stereo a couple of times. Ideas? I can't find her Audio manual. Is it something as simple as a bad ground or a fuse?
Did you mess with the setting in the radio menu? You can set the startup volume under that menu... I think 15 was the max.
Yep. It will revert back after so many starts. Weird. It does appear to be blaring from just the front speakers, but occasionally just the driver's door or jump to the "am" setting. It has a mind of it's own. Someone suggested maybe the steering wheel switches? Bizarre trolls at work.
I have not. Fuses look fine. It's obviously beyond my knowledge. I'm just trying to give my sister a direction with this issue.
1 - 7 of 7 Posts
