1 - 2 of 2 Posts
Hey everyone ;)
My car can't start. If I switch to ignition the check engine light doesn't appear, but there are a traction and stability control errors.
After trying to start the car nothing happens. I've checked the fuses under the bonnet and try to use another battery, but the problem is still the same. I can't connect via obd II and check the ECU errors. Earlier, the odb II worked.
Any solutions ? I thought about the broken ECU, but what should I check also before ?
Regards
1 - 2 of 2 Posts
