Hello everyone. Could use some help. 01 SE ragtop, passenger power seat will not recline. No sound at all when trying switch nor any movement. All other functions work perfectly and smoothly. Took switch from drivers seat and tried on pass. seat but no difference. Looked under seat and all appears proper, though there are two small connectors on the same harness that are not hooked up to anything
One is yellow in color and the other is Gray. Seat heater works so not associated with that. The current seat back position is okay for short distance but very uncomfortable otherwise. Bought car 1 year ago and have been working on this problem since day one. I am down to just 2 problems left to correct, this seat issue and problem with the top. Any and all assistance is greatly appreciated. Limited on tools and knowledge of Saabs.
Seat or backrest?
Backrest have cables between motors and backrest.
Grey connector is seat belt lock and yellow is side airbag.
The seat back is what will not recline. The is no sound at all when engaging the switch. Was thinking might be motor, but pass. has hardly ever been used. The seat appears pristine, garages kept and only 120,000 miles. As for those connectors, have not found the respective mates to connect them.
