I had noticed crankcase fumes around the car since we bought it a few months ago, I went ahead and replaced all the vac lines and noticed the arrow on the PCV valve was pointing away from the throttle body.
I assume that is the reason for the fumes, could this cause any other issues?
Probably not. The valve really only allows fumes to get sucked up when you are idling. Under boost, the fumes go a different route.
