Does anyone know what this means or where I would go in the Tech2 menu to correct it?
I get “configuration mismatch” error when scanning for DTCs with Tech2.
“Automatic low beam also in Pos 0”
“Automatic low beam only in Pos 2”
277270
277271
It offers to automatically fix it for me, but I’m concerned what functionality will change (perhaps away from how I like it today).
Thanks in advance!
You must have changed the settings to turn off the daytime running lights, which has to be done in three places. You're getting the error because the BCM's setting is inconsistent with the UEC (front lights) and REC (rear lights).
I've come across this once before. If you press repair, it should allow you to choose the setting you want (presumably the "only in position 2" setting) and it will make the change for you. You can also re-add the BCM.
Thank you both!!! Yes, I did have the car programmed back when I bought it to allow the daytime running lights to be turned off.
I’ll make the changes you recommended. Thank you again!
