Strange part under the throttle body ??? - SaabCentral Forums
Old 6th April 2019
marcjero marcjero is offline
My Saabs: 02 og 9-3 Aero 205
Default Strange part under the throttle body ???
Hi,
I just removed the throttle body in order to replace the gaskets.
But under the throttle body there is a plate with a a kind of basket fitted inside the manifold. There is no gasket under this part so I'm worrying about the air leak that could happen here.
What is this part for ? I don't see it in air intake schemas... Looks like a restrictor or something to stabilize airflow in the manifold.
Thank you.
Old 6th April 2019
Mimmi's Avatar
Mimmi Mimmi is online now
My Saabs: Hirsch fleet: 2*9-5 + 9-3
Outer part is gasket (P/N 9189713). Inner part is air distributor (9189481).
EPC shows them under engine, inlet and exhaust system, throttle body.
Sorry, but I am not mind reader, so I just answer questions.
Old 6th April 2019
Weyfarere Weyfarere is offline
My Saabs: 1999 9-3
Just when you think you've seen just about every part, someone has to go and find another.
And Mimmi answers it just like that.
RIP: 1988 900S, 1995 V6 900 SE vert, 1995 900 SE vert, 1994 900 S Coupe, 1998 900 SE turbo, 900 SE vert, 1999 9-3 Coupe
Sold: 1996 900, 1996 900S
Have: 1999 9-3 4-dr
Old 6th April 2019
Thank you !
Problem is I don't have the gasket so it is not good. I understand the distributor was not fitted in all B205 so I guess I can just remove it ?
Well in fact the gasket is here or more likely what happened to be a gasket long time ago.
Old 6th April 2019
BobSaabit's Avatar
BobSaabit BobSaabit is online now
Saabista
My Saabs: '03 9 'vert; '01 9 5d & parts car;
I believe it was on all T7's.
Old 6th April 2019
I don't think so. Looks like it was installed on 2002-2003 9-3 and some 9-5 got it also. I watched to a tutorial about replacing the throttle body (9-5) and the car didn't have that one. Funny thing is that the 9-5 built after 2003 didn't get this distributor anymore.
Old 6th April 2019
hiloh_3 hiloh_3 is offline
My Saabs: 1999 9 3 SE
Originally Posted by marcjero View Post
Thank you !
Looks like that gasket is available at Esaab and Euro for under $6
Old 8th April 2019
Mimmi's Avatar
Pic is not yours?
I see clearly gasket in that pic.
Old 8th April 2019
Yes it is, the gasket is on the back.
Old 8th April 2019
LEP3 LEP3 is offline
My Saabs: 2001 9-3 Viggen Convertible
Perhaps this an "optional" part?
Old 8th April 2019
I don't have this option anymore
I found that there was a bit of oil in this area. I suppose this thing helps catching oil vapours.
Old 8th April 2019
Mimmi's Avatar
Why not just order part? I gave you part number.
Old 8th April 2019
I will do. But I need to drive the car.
Old 9th April 2019
Doug's Avatar
Doug Doug is offline
My Saabs: '97 9000 Aero. '04 9-5 Aero estate
The question is - was it discontinued as a cost-cutting measure, because it was found to be useless?
Old 9th April 2019
To be honest I don't feel anything bad after removing it.
Old 9th April 2019
Danno93 Danno93 is offline
My Saabs: 1999 9-3SE, 2002 9-3SE, 2002 93 SE 'vert
Garage
The WIS says on "LEV cars" ( not sure what that means...) "there is an air strainer fitted under the throttle body that distributes air as evenly as possible to the different cylinders to attain an even combustion"
Old 9th April 2019
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: '97 900SE Talladega, 2000 9-5 Aero Wagon
I had a 2001 9-3 that had that strainer, and now have a 2000 and a 2001 9-5 that don't. That's interesting that it was there to distribute air to the cylinders. It reminds of the clips they used to use on the fuel injectors on the 9000 and NG900. There were two, and each one clipped two injectors together. There was an old press release that said the clips kept the injectors aligned properly so that they'd spray fuel in the optimal direction. They were dropped around 1998. I don't know if the 9-3 and 9-5 kept the injectors aligned by a different method, or if Saab just decided it wasn't worth it anymore, possibly like the intake manifold strainer.
Old 9th April 2019
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: None at the moment
LEV is low emission vehicle. I suspect it was only on cars that were ordered in states that required cars to be CA compliant.
I think those clips were a T5 thing, I remember dealing with them when doing head gaskets on a 1999 9-3. I suspect the T7 cars hold the injectors in place via a different method since the fuel rail and injectors are different, or maybe the injectors spray in a cone pattern rather than a fan so don't require alignment.
Old 9th April 2019
Mimmi's Avatar
"LEV cars"
Low Emission Vehicle.
Old 9th April 2019
Well my car was sold in Sweden and is Euro 4 compliant. Would be interesting to know if 2005-2006 9-5 got the strainer or not. BTW I think I fixed some leaks because now my E85 adaptation is accurate and the engine is working very well. I hope it will last this way.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
P0638 P1681 Codes (throttle body and throttle actuator control) Samiorga 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 2nd January 2018 06:50 PM
Throttle Body Surging -- Solved? SectorNine50 9-5 Workshop 79 20th March 2012 01:34 PM
Throttle Body Hose Connections- Help Needed ldinnc NG900 & OG9-3 Workshop 5 22nd January 2011 02:36 PM
throttle body seal replacement saabrider C900 Workshop 1 2nd July 2006 10:43 PM
Throttle body versions Mike Bz 9-5 Workshop 3 2nd February 2004 11:33 AM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
