Can a Tech 2 program a throttle body from a 93 9000 Aero? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Tech II Workshop
Notices
Tech II Workshop For all discussions regarding the Tech II onboard diagnostics tool.
Old 22nd June 2016
weirdaljr weirdaljr is offline
My Saabs: None
Default Can a Tech 2 program a throttle body from a 93 9000 Aero?
I am getting conflicting information from my research and searching. Can a Tech 2 with Saab card and tis2000 or globaltis program a throttle body in a 1993 9000 Aero? I have read that a Tech 2 can, also that a Tech 2 can not and only a ISAT can, and also that both can do it.
Can anyone kindly confirm if a Tech 2 can program it or not? If so it would be great if anyone knew the procedure or could tell me the correct manual I can look it up in it would be greatly appreciated.
Old 22nd June 2016
SPG900T's Avatar
SPG900T SPG900T is offline
My Saabs: 91 SPG T5, 05 9-5 Aero, 08 9-3SS Hirsch
Garage
Yes it can. If you have all the right pieces. V43 or V44 on a card and LOL their ain't no stinking manual for that process but your in luck.
Calibration should be performed after major engine work, when any TCS component has been replaced or when the battery has been disconnected.
This PI will detail the process for calibrating the ETS/TCS using the Tech2. Before following this PI all faults must be remedied and all codes cleared. The car must also be at operating temperature, let the radiator fans cycle 2x. Park the car on a level surface and engage the handbrake. (The vehicle must not move during the cal process)
IMPORTANT: WARM CAR UP TILL FANS CYCLE 2X. (If vehicle will not idle see instructions for cal code 974 in STEP-2 below.)
SET HAND BRAKE TO PREVENT VEHICLE MOVEMENT
STEP-1
Build the vehicle using Tech2.
Select the Diagnostic menu
Select Engine
Next select ETS
Then select programming
Select the appropriate engine variant and confirm selection, then Tech2 should confirm selection.
Exit all the way back out of vehicle menus, turn Tech2 off then cycle vehicle key.
This first step insures correct engine variant/calibration is installed.
STEP-2
Restart Tech2 and proceed building vehicle and navigate back to the menu for ETS.
Then select the Read Value/Activate menu.
Then select the Activate menu again.
At this point several activation options will be displayed, we are concerned with 3.
971 - Is the ETS baseline calibration
973 - Is the ETS main calibration
974 - Is the ETS calibration used when the car will not idle long enough to get warm (Use as the first step if car will not idle long enough to warm up properly, then repeat from Step-1. (N/A provided that STEP-1 was performed previously)
Select 971 and then enter/start. (Tech2 will display "unknown", then "started", then "finished" in a very rapid sequence)
NOTE: If you perform any other function with Tech2 before doing the 971 baseline setting, you will need to shut down Tech 2, cycle the ignition key and re-establish communications with ETS. Failure to do this will result in the baseline setting not showing ''finished" on the Tech 2 screen.
STEP-3
After completing the 971-baseline programming select 973 and enter/start programming.
Watch for the TCS light to come on in the Instrument panel.
Start Engine. DO NOT TOUCH ANY PEDALS.
When TCS light begins to flash the RPM's will start automatically to climb towards approximately 3000 rpm then stabilize and fall after several seconds to about 900rpm and begin to stabilize again.
The TCS light should go out when calibration is completed.
When completed end Tech2 communications and recheck to see if any fault codes were stored during calibration.
Test drive to verify repair.
NOTE: If replacing the Pedal Potentiometer you may need to update the wiring harness as described below.
When ordering throttle pedal potentiometer 4301685 from parts stock, please be aware that these potentiometers have been updated with new gold terminals to better resist corrosion.
When installing the new style potentiometer, part no. 4301685, it may be necessary to also order five gold female terminals, part no. 4063087, so that the wiring harness can be appropriately updated. DO NOT mix gold and tin terminals.
Old 22nd June 2016
My Saabs: None
Wow SPG900T thanks so much, great info!
Happen to know the location of the port on this? I saw on the forums that it may be under a carpet flap by drivers seat. Happen to know if that is correct? I also saw a mention of needing a 10-pin adapter for this car. I haven't found a supplier yet, but I wanted to verify the info is correct if possible before I get there.
Thanks again, awesome info!
Old 23rd June 2016
SPG900T's Avatar
Garage
The port is under the passenger seat (USA) and yes you will also need the 10 pin adapter. eBay will probably be your best bet for the 10 pin Saab adapter
Old 23rd June 2016
swedespeed7's Avatar
swedespeed7 swedespeed7 is offline
My Saabs: 2008 9 Aero SS, 2011 9-4X Aero
Garage
SAAB 9000 TCS
Past SAABs: '93, '94, and '95 9000 Aeros, '01 Viggen, '09 2.0T SS
Old 23rd June 2016
My Saabs: None
Thanks again, I truly appreciate it!
Old 23rd June 2016
My Saabs: None
Originally Posted by swedespeed7 View Post
SAAB 9000 TCS
Sorry not sure what you mean?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
HTML code is On
Similar Threads
Can a Tech 2 with Tis2Win Program a 1993 Aero Throttle Body? weirdaljr Tech II Workshop 2 21st June 2016 01:10 PM
throttle body swap requires tech II??? rkymtnman NG900 & OG9-3 Workshop 2 30th January 2016 05:04 PM
Wanted: 9000 sensors and 900 throttle body SOAB Parts for Sale/Wanted - North America 2 2nd October 2010 01:50 PM
Replacing throttle body. Tech 2 or software calibration required? duracell 9-5 Workshop 9 3rd July 2008 09:29 AM
9000 Aero Throttle Body Screens SMSAERO 9000 Workshop 7 6th February 2007 08:58 PM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
