ACC panel pixel fix - SaabCentral Forums
Old 14th August 2005
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Default ACC panel pixel fix
Loads of people have covered the SID pixel fix, but i found the ACC pixel fix to be a totally different procedure so here goes. Tools needed T6, 7, 8 torx bits, small flat blade screwdriver, polystyrene foam and a very sharp knife to cut the foam.
remove the screw either side of the casing, then remove the screw attached to the PCB on either side. using the small screwdriver undo the 4 plastic clips (2 top and 2 bottom).slowly slide the rear panel off the ACC unit
undo the 3 screws attaching the pcb to the front
slide the pcb out of the front of the ACC unit
here's the awkward bit, unclip the lower two tabs so the display hinges upwards, then insert some polystyrene foam about 4mm square by 7cm long into the gap of the ribbon connector
the foam is inserted in this picture and the lower tabs reconnected trapping the foam in the ribbon. re-assembly in reverse order.
poor picture i know, but the whole ACC display is now pixel perfect.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Excellent thread Kermit, thanks
Old 5th September 2005
saber-95 saber-95 is offline
My Saabs: 98 2.3 SE Stg 2
Can't thank you enough Kermit, it's worked a treat for me and saved a lot of money as well, as no need to replace it, (unlike the SID )
Old 6th October 2005
pokerplayer's Avatar
pokerplayer pokerplayer is offline
Banned
My Saabs: 1999 4cyl 9-5
Default awesome
Thank you Kermit! I'll try it tonite, will let you know how it went.
Banned
Hey Kermit!
I did not try it yet, but I will try this fix. I wonder, what is the trick for the foam? Is it something chemical? Because obviously, it is a lot harder than the wheather strip.
thank you
(nice fingers)
Banned
You said INTO THE GAP OF THE RIBBON CONNECTOR, clarify please? I stick it where it rolls?or folds?
thank you
Old 27th October 2005
Banned
Done, fixed.
Thank you Kermit
Old 28th October 2005
Kermit's Avatar
Saabista
It goes through the ribbon connector like a surfer riding a tube. The theory is the ribbon connector is stretched around the piece of foam, which pulls the contact points on the PCD down and re-establishes any lost connection points.
Old 1st November 2005
NJDav's Avatar
NJDav NJDav is offline
My Saabs: 1998 9-5 2.0t SE Ecopower
Default Newbie question
on my 1998 95 which i just bought and am very pleased with, i noticed that the word AUTO dos not display on the ACC control panel, is this the pixel fault mentioned above?
if so, this looks like a great fix, i did take the unit out to have a look to see if it was just a bulb, but couldn't get the 2 allen key type screws out inorder to remove the plastic house that stops you removing the bulb holders.
any idea what size allen key is need for that??
i look forward to some answers, as i can see you guys are a helpful bunch.
cheers
NJDav
xxxxxxxxxxxxxxxxxFinn
Guest
Posts: n/a
cheers
NJDav
have you tried pressing the auto button and turning auto on
Banned
NJDav
7 or 8 I believe, and it is torq wrench or driver...
Guest
Posts: n/a
Arnt they in the saab toolkit in the boot
NJDav's Avatar
thanks for the quick replies guys.
and yes i have tried pressing the auto button, i may be new to a saab, i'm not new to button and light, and how they interact. lol
thanks for the tip about the tool kit in the boot, found, but it's no the right size torx driver, and yes i checked both end, they are all to big.
will try and get the correct torx bit and have another go.
all this help, but no one has actually confirmed if the word auto missing off the display is the pixel problem or not, all the other symbols etc work, just the word auto missing. did the 98 model even say auto on the display??
many thanks
Banned
many thanks
I had same problem, open the unit fiddle little bit (extremely gently) do what these people say or read other posts. My AUTO came back now. I also did the last fix as Kermit posted with that white foam thing. Everything is working now. That ribbon connction is never tight enough!
Old 28th February 2006
Sad9-5 Sad9-5 is offline
My Saabs: 1999 9-5 2.3t SE B235E Engine
Gave this a go and I only got the second digit back on the left side of the display. Auto, degree's C, and the fan bars still not there. This does show that the idea does work, though in my case not all of the pixels are back.
Right side is OK.
May be I need to pack out the foam a bit more.
Or does anyone know someone who does repair these units by re-soldering. At a reasonable cost?
Old 1st March 2006
jedi_master58's Avatar
jedi_master58 jedi_master58 is offline
Location: Toronto, Ontario, Canada - 2007 Saab 9-3SS 2.0T, 1999 Saab 9-5 lpt
My Saabs: 2007 Saab 9-3SS 2.0T 4cyl
Great post, thanks Kermit, will definaly give it a shot!
Any Idea where you can purchase the polystyrene foam?
Old 1st March 2006
Kermit's Avatar
Saabista
I got mine from the packing of a DVD player, most electricals come cushioned in the box with it.
Old 2nd March 2006
Clever! the foam is basically the part that holds the dvd player or other electronic components in place right? This sounds like such a stupid question but I want to get it right!!
Old 2nd March 2006
Kermit's Avatar
Saabista
Correct, just take a very sharp knife to it.
Old 4th March 2006
serencavalier's Avatar
serencavalier serencavalier is offline
My Saabs: 9-5 SE V6
Can you guys make this a Sticky?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
