Technical Service Bulletins - Saab 9-5 - SaabCentral Forums
Old 25th June 2005
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Default Technical Service Bulletins - Saab 9-5
9-5
113-2084
Changes to Saab original service program
9-5
99-02-852b
New memory connector for front seats
9-5
99-02-510c
Brake linings, special types of driving
9-5
99-01-371
Fault diagnosis hints related to grounding points G41S and G41P
9-5
98-10-371
Poor contact at Grounding point G30
9-5
371-2128
Adjusting wiring harness at ABS bracket
9-5
367-1960
Replacing the Audio System
9-5
340-2030
Starter motor must crank for a long time before engine starts
9-5
801-2080
Water leak on left-hand side of cabin
9-5
771-1886
New wheel bolt
9-5
732-1854
Inspection of rear suspension
9-5
644-1875ed2
Synthetic power steering fluid as a spare part
9-5
644-1853
Inspection of power steering return hose fastening
9-5
641-2115
Cold downdraft from steering wheel
9-5
524-1890
Pedal raising kit
9-5
522-1852
Inspection of brake pedal
9-5
510-1912
Vibration while braking
9-5
381-1933
SID message “Time For Service”
9-5
98-12-843
Door mirror casing comes loose
9-5
987-1858
Parking heater
9-5
890-1882
Base solid paints with clear enamel
9-5
855-2088
Road Noise in cabin
9-5
853-2173
Seat-belt warning, Damaged cable
9-5
852-1851
Inspection of tilt function, manual seats
9-5
850-2077
Spurious diagnostic codes in the airbag ( SRS )
9-5
850-2001
Affixing airbag label
9-5
843-1953
Juddering side windows
9-5
99-02-831
Wind noise from front side windows
9-5
391-1964
Hands free installation and glass mounted mobile telephone
9-5
210-2123
Battery cover chafes aginst engine cover
9-5
831-2085
Reprogramming tailgate locking logic
9-5
522-2118
Noise during braking
9-5
432-2138
Shift - lock solenoid
Old 31st October 2006
jsmith27 jsmith27 is offline
My Saabs: 2002 9-5 aero
can you post 210-2402?
thank you
Old 10th October 2010
judgegarry's Avatar
judgegarry judgegarry is offline
My Saabs: 2000 9-5 2.3T
Question
So what happened to the bulletin for the PCV upgrade?
Nathan 9⁵'s Avatar
Nathan 9⁵ Nathan 9⁵ is offline
My Saabs: '01&'03 9⁵ 3.0t '04 9³ 2.0T '06 97
What an awesome thread!
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
There wasn't a TSB for it in 2005 when the thread was written............
thinkglad's Avatar
thinkglad thinkglad is offline
My Saabs: 2002 9-5 Aero, 1995 900SE Vert. ( Sold )
This indeed is good info to have handy
Old 12th October 2010
judgegarry's Avatar
Sorry, didn't realize it's an old post. Excuse the newbie.
Just in case someone is copying your list without knowing about the zillion post on the subject, the bulletin is
TSB 210-2417 ed. 4.
Do you know of any more important TSB's that came after you posted ?
Carpe Diem
Jssaab Jssaab is offline
My Saabs: 2003 Aero Hirsch "Clone"
Can't you just go on all data or here: http://www.allworldauto.com/tsbs/saa...41-6585-1.html
I thinnk teh NTSB keep em too
Old 27th November 2010
gdelius gdelius is offline
New Member
My Saabs: 2001, 9.5, SE, 3.0T, 145K
Default Manuals for 2001 9-5, v6, 3.0 turbo aero?
I've been a saab owner for years owned 4 and rebuilt the engines on 2, and recently decided to pick-up an early 2000's model to reduce the mileage I was racking up on my new truck (and to actually enjoy the drive back and forth to work each day rather than dreading it...)
I found a stunning 2001, 9-5, 3.0 v6 Turbo for about half the blue book and snapped it up.
The current owners says the CEL is on because of a code for the theft deterrent system (??)
Now I'm trying to locate the shop manuals for this engine and am coming up with nothing. I see DVD's on Ebay and am wondering if they are how this engine was supported? any help would be appreciated.
Welcome to SaabCentral!!!
Yes the manuals on on CD it is called WIS ( workshop information System)
Read the codes and report back the only theft code is for the immobilizer IIRC
Oh and its best to post a separate thread with your problem instead of replying to an unrelated thread to get the most responses
New Member
Default The joys of being a newbie!
Thanks for the info on the DVD's they are a cheap enough solution!
I thought I HAD started a new thread, Blush...
I pick the car up tomorrow from the previous owner and haven't ordered a code reader yet. As soon as I trap the codes I'll report back.
Thanks for your reply and guidance...
Old 20th December 2010
zoli.m13's Avatar
zoli.m13 zoli.m13 is offline
My Saabs: MY98 9-5 B205E SE M/T
Garage
Question
Hi,
This link looks useful - but I can't see any possibilities to download/open the TSB!
Originally Posted by zoli.m13 View Post
Hi,
dead link try the governmetn supplied one:
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
zoli.m13's Avatar
Garage
Unhappy
Thanks for this - I checked it and it's not free...
Any other source of TSB's?
Old 21st December 2010
Is for me, becasue you are outside the US maybe, interesting
Old 12th October 2011
topbiz12 topbiz12 is offline
New Member
My Saabs: 1
Default Must disconnect battery for car to start
Any thoughts? I have a 2000 9-5 . The car did not start about 2 weeks ago, even though battery was only 18 months old, and had plenty of cranking power. Bought a new battery and had it installed. Car started right up. Next day, would not start. When this happens, I disconnect battery, hook back up, and it starts. Today it showed both engine malfunction light and Fault Indicator, automatic transmission light. Brought it to autzone, had tool hooked up and showed 1701 code. Tried to start car, had to disconnect battery, then hooked back up, both lights off, car started.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
