Prestige 300 Sound System - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Audio, Video, Navigation & Security
Audio, Video, Navigation & Security Discussions about in-car infotainment, navigation and security systems - independent of car model and year.
Closed Thread
Old 6th February 2013
VinceV's Avatar
VinceV VinceV is offline
My Saabs: 2003 9³ Arc BSR Stg1 6spd
Garage
Default Prestige 300 Sound System
I recently re-worked my sound system and by-passed the factory system. I installed a Nakamichi CD player in the DIN opening where the CD player is and modified the trim from the non-working player to cover the gap. The Nak head unit powers all speakers in the car except for the Infinity Basslink. All speakers have custom crossovers to keep the impedance a 4ohms - pretty much like how home speaker crossovers work. Here are the notes I took for wiring and amp locations.
Quick reply to this message
Old 7th February 2013
EuroStyle's Avatar
EuroStyle EuroStyle is offline
My Saabs: 2006 9-3 Aero Convertible 2.8TM, Vtune 0
Nice for reference, thanks....
Sean
2006 Saab Cars, N.A. "Top Gun"
Saab Aero Academy Alumni
VinceV's Avatar
Garage
Did this just for fun!
VinceV's Avatar
Garage
Here's a pic of the CD45z in the lower DIN opening.
Old 13th February 2013
SovangW's Avatar
SovangW SovangW is offline
My Saabs: 03' 9³ BCB Stage 2
Garage
how much to have you install if i come up to CT with all the parts
Zombie_aero Zombie_aero is offline
My Saabs: 2004 9-3 Aero convertible 2.0T Noobtuned
I've thought about doing this as well, I never use the cd changer due to my AUX in, did you use original wiring or run your own from the new headunit ? What does the SID now show ? Is it working correctly for the other functions ?
Old 18th February 2013
VinceV's Avatar
Garage
My stock radio still works - I left AMP1 under the drivers seat connected and it runs the center and door speakers - actually doesn't sound that bad. Good for listening to the news. I did use the wiring for the front 3 1/2 seperates and the 4" inch rear separates that come off of the EHU - this allowed me to branch of from there to the remaining speakers. I will eventually install seperate amps for the speakers, but for now it works and sounds pretty amazing as it is.
Oh, I did use diodes to keep the signal from one system feeding back into the other - essentially have two sound systems working in the car.
VinceV's Avatar
Garage
I just moved back to CT from NC! I'm not doing sound professionally anymore, but can offer any information that you might need with getting your system up and running. Cheers!
Old 6th March 2013
griffin dai's Avatar
griffin dai griffin dai is offline
My Saabs: JZW Stage 5 9³ v6 Aero
Hi, how did you do this? Looks a very neat job
Did the new head unit just slide/lock into place as it does on a normal single din equipped car or did you have to replace and modify a new cage to fit?
Old 6th March 2013
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
Very nice job. We could of used you around here about 10 years ago when the system just came out and nobody could figure the thing out.
And Nakamichi is still in business? I had some components in the 80's of them--they were state of the art back then.
03' SS Linear Cosmic Blue, 109k mi., gone
06' SC Aero Auto Fusion Blue, BSR tuned, 94k gone.
09' SS Aero XWD Auto
Carbon Gray, Black Premium Leather, VTuned, 30% tint.
Old 6th March 2013
VinceV's Avatar
Garage
griffin - yes, just slid right in and actually it just sits there perfectly like it was meant to be. The trim worked out that all I needed was double stick tape on the top to hold it in place.
Cosmic - This was a fun system to figure out! The factory system wasn't bad, but I like quick and easy control of my sound, plus the Nak provides two AUX inputs and 3 low level outputs - and it will play any CD I put in it without skipping a beat. Back in the 80's there was some great equipment out there and I still like alot of the old school stuff!
Old 6th March 2013
So for the fascia did you simply detach it from the old CD player then cut it to single din size? Does the fascia then clip back in ok?
I'll be fitting a flip down Pioneer DEH-80PRS if I go this route, just concerned about it fouling the bottom trim when I drop the face to insert a CD or need to pull the face out at night.
Have you left the fibre optic cables and original amps in place then routed new speaker cables/amps?
Old 6th March 2013
VinceV's Avatar
Garage
Yes, it's cut din size but there's no bottom - just sides and top - I'll take a picture tomorrow and post.
First try fitting your radio in the location to see how it works as it sits in there.
Yes, all fiber optics in place, just bypassed the on for the CD player.
Old 6th March 2013
What sort of diodes did you use to stop the signal feeding back, maybe you could update your install diagram you posted with the location of them ?
Old 7th March 2013
Thats great help thanks
I was all set to get a 9-5 Aero but this audio info has really swayed me towards the 9-3 instead! I've always fancied the v6 Aero
Old 30th June 2013
Thought it best to ask you've been and done it!!
How did you tap into the cars existing wiring to power up the new head unit? I've done quite a bit to mine over the last month, mainly deadening, but just cant figure out a way to power my Pioneer unit up and where to connect the following:
Switched +12v
Permanent +12v
Earth
Illumination
The head units fitted but nothings wired up yet, fibre optic loops in place behind the CD player and its working fine and I'm keeping both Amps 1 & 2 connected to the ECU to save anymore hassle....but they wont be used.
Also how did you secure your Nakamichi into the cage? Did the locking pins catch ok and hold it there? This Pioneer slides in fine...but keeps on going! I'm thinking maybe a couple small screws each side will hold it securely? My ash tray also needs to be trimmed as I cant get the bloody face down far enough to change CD's
Thread Here:
https://www.saabcentral.com/forums/sh...=252839&page=5
^^^^^getting there slowly
On a side note, I missed out on a Nakamichi CD-45z last week....my connection dropped and I got outbid Gutted....no....I'm devastated!!!!! I'd love to try one side by side with this DEH-80PRS then keep one and sell the other, I bet the Nak sounds nicer
Old 14th August 2017
SaabBoston SaabBoston is offline
My Saabs: 2005 Saab 9-3 Sedan Linear
My friend. If my Amp1 is gone can I recover the bass signals that go to this device via the fiber optic?
What is cheaper and better in your opinion:
1. A new aftermarket radio and bypassing Amp1 (fiber optics loop)
2. Getting a new Saab Amp1 fro Eeuroparts?
My goal is to have all the audio frequencies. I know I could get a basic aftermarket amp, bring signal from the dash speakers and have all my 6 speakers sounding (center dash is disconnected), but that would sound horrible without the bass.
What do you recommend?
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear; 2015 VW GTI
Already answered in audio section.
The answer is almost always....Tech2.
You can either buy one or be a slave to your mechanic/dealer when you need repairs. Your choice.
Never have less than TWO working key fobs.
Closed Thread
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
SS '03 - Prestige 300W system. 13 speakers, upgradeable? nairua 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 16th January 2011 01:28 PM
Center Speaker Blown HK Prestige system - Questions?? Kyled427 9-5 Performance, Mods & Tuning 12 30th May 2009 06:25 PM
Anyone like the "prestige" 300 sound system? Vectorized 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 13 20th March 2009 12:00 PM
Decoding professional sound system discs? DMX Sound system, Help boon94 The Lounge 0 8th August 2007 11:03 PM
2002 9-5 Linear "Prestige" audio system vs. 2003 9-5 Aero system revenire 9-5 Workshop 11 15th August 2006 12:32 PM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
