2004 95 Limp mode reset - SaabCentral Forums
Old 28th February 2004
Lanceber's Avatar
Lanceber Lanceber is offline
My Saabs: 2004 95 Aero (My 6th Saab)
Default 2004 95 Limp mode reset
I will try to describe the process. Very easy when you see it done, not so easy to have it explained.
On my 2004 95 Aero it went into limp mode, both electronically and mechanically. Here is the procedure as I know it, if there some mechanics out there and this is not correct then please chime in.
- Disconnect the battery + cable
- Remove the black plastic cover that hides the TB and is around the Oil dip stick.
- On the passenger side of the TB you will see a black metal cover plate, remove it (2 X 10mm) bolts. This will expose the cable/spring wheel that the throttle cable is attached to.
- If you look directly at the wheel you have a front piece and a back piece. The back piece has some ridges on the top surface.
- In normal mode only the outer piece should move with the push of the pedal. In limp mode both pieces move.
- The object is to reset the back piece. You must rotate it counter clockwise till it clicks into place and is held by a switch. You will see this switch as it has 2 wires coming off it and is on you left if you are looking straight on to the wheels.
- You will not be able to move the back wheel back until you release the spring that is sticking out the bottom around 5 o-clock. This metal spring tab needs to be moved to the other side of the black plastic piece. You can do this with your finger and press it back and it will pop around the black tab on the back wheel. Once the spring releases you will be able to easily rotate the back wheel counterclockwise into place.
- You will know it is correct if you move the throttle cable and only the front wheel moves and the back wheel that you locked into place stays put.
- Reconnect the battery (This was to reset the ECU check engine code).
Like I said it is a little hard to describe but very very easy once you have done it.
Hope this helps,
Lance from Houston
2004 Steel Grey 95 Aero, PPC Stage-3, 18" Ronal LV's
Old 31st March 2004
Mattlach's Avatar
Mattlach Mattlach is offline
My Saabs: 2009 Volvo S80 T6 AWD
What is this "Limp Mode" of which you speak?
Old 8th April 2004
DrBoost's Avatar
DrBoost DrBoost is offline
My Saabs: 9000 B234R+ M/98 and 9-5 Aero Sedan M/01
Hej !
The throttle control will be tured off if a "throttle fault" is being detected. Normally the throttle butterfly is activated by a motor controlled by ECM, but when set in limphome, this is turned off and the butterfly is mechanicly connected to the bowden cable from the loud pedal.
I do not recommed you to do this reset, because you LOOSE the DTC that triggerd the limphome.
Result: difficult to find tha actual fault, maybe I should use the word impossible.
Old 10th November 2004
NGB's Avatar
NGB NGB is offline
Banned
My Saabs: SAAB 9-5 Aero wagon 01
one add:
after that that you discrabe "off limp home" ..
recomended shorten trottle cable 1-2mm..
this "off limp home" better to do if not posible to went to SAAB-workshop ore nears SAAB-workshop as far ..
Old 25th May 2008
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Reset videos:
Here - http://mx.truveo.com/How-to-reset-a-...m/id/116715131
Or: http://hk.youtube.com/watch?v=nlqyT9eNMuU
Old 11th November 2009
jonnyb3123 jonnyb3123 is offline
My Saabs: 2001 9-5 Aero
Default Limp Home solenoid reset. Now car will not fire up.
I have just reset my limp home solenoid after replacing a split hose on crankcase ventilation system on my 2001 9-5 aero auto.( The one from valve cover to oil seperator with line teeing off towards pcv check valve/ throttle body) Now my car will not start up although prior to resetting solenoid it did! What is going on now?
Ta
JB
Old 17th December 2010
NHTIM NHTIM is offline
My Saabs: saab
Is my Saab 9-5 in Limp mode?
My check engine light is on and off for unknown reasons
MPG rarely averages over 17 mpg
Car as whole feels sluggish
What circumstances would warrant the Limp mode activation
2001 2.3 Aero
What extent does Limp mode handicap performance?
Old 18th December 2010
lesenyap lesenyap is offline
My Saabs: 1998 95 se 20t (bmw worrier)
2001 2.3 Aero
If it was in lhm you would know ,the cel light would not not go off and it would not idle very well ,its more likely to be something else like ,the maf or the o2 senser even a 2.3 auto should get 23_24 mpg !
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
