Replacing Cabin Air Filters - SaabCentral Forums
Old 14th May 2010
J-Rod's Avatar
J-Rod J-Rod is offline
My Saabs: 2003 9-5 ARC, 2000 9-5 SC Aero Clone
Garage
Question Replacing Cabin Air Filters
Honestly, I have no idea when the filters were last replaced and I have owned the car for almost a year, so they definitely need to be replaced. How do you do this? The car is a 2003 9-5 Arc. Pictures would be helpful. Also where can I get these filters?
Old 14th May 2010
Sparky's 9-5 3t's Avatar
Sparky's 9-5 3t Sparky's 9-5 3t is offline
My Saabs: "Freja"- '03 9-5 V6 Arc by Rabbit
https://www.saabcentral.com/forums/sh...d.php?t=117261
but no idea where to purchase them from. I should probably be doing this too, lol.
--T7 Suited V6 by Rabbit--Taliaferro K&N assembly--Relay 666--Rear fog light mod--6k HID headlamps--18" SS wheels--245/40/18 Yokohama Advans--Blacked-out front grill--
Old 14th May 2010
J-Rod's Avatar
Garage
Cool thanks! Mine, I bet, are really nasty. I've been getting a bad smell in the car so this is probably it. Is there only one filter?
Old 14th May 2010
Personally, I have no clue. Never got down in there to check it out. The photo's on the link show only 1 filter it looks like.
Old 14th May 2010
J-Rod's Avatar
Garage
That's what it looks lie to me too. But I heard that they have 7.
Old 14th May 2010
MI-Roger MI-Roger is offline
My Saabs: '08 9-5 Aero, '06 9-3SC, '00 Viggen
Default One filter.........
The 1998 thru early 2000 models were shipped from the factory with two filters (a thin pleated filter for dirt and a carbon filter for odors), but beginning with the mid-2000 model years all cars now have a single thicker dual use filter.
I have bought these filters from the Dealer, from eEuroparts, from thesaabsite, possibly from GenuineSaab, and they may even be available from AutoZone or other parts places as a Purolator part.
Old 14th May 2010
J-Rod's Avatar
Garage
Cool, thanks. How much were they?
Old 14th May 2010
Default Ouch!!
Current prices are:
Aftermarket - $22
SAAB OEM - $54
Old 14th May 2010
zachc's Avatar
zachc zachc is offline
My Saabs: 91 900 turbo resto.
Garage
this is really easy to do.
take out glove box. take off lower cover where passenger feet go. cover is on left hand side.(three bobby pins, push in center tab and then pull out) remove black plastic cover behind cover. 8 torx screws i think. cant remember been awhile. take this off and remove filter.
do the reverse of removal. takes about 20 mins.
I <3 SAAB, so i tattooed the Griffin on my arm.
Old 14th May 2010
J-Rod's Avatar
Garage
Current prices are:
Aftermarket - $22
SAAB OEM - $54
Thanks. How good are the aftermarket ones? Quite a difference in price, so if there isn't a big difference in quality, I'd like to save some money.
Old 15th May 2010
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Where is the second filter?
Old 15th May 2010
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
There's only one. I think the earlier ones came with two sandwiched together. In the same place.
Old 15th May 2010
Here, I finally made a DIY with all the pictures I took when I did mine.
http://sites.google.com/site/saabdiy/Home
Old 15th May 2010
mike427's Avatar
mike427 mike427 is offline
My Saabs: 2005 9-5 ARC
I have used the Aftermarket filters for about 2 years now. I replace mine every year. It helps the AC runn cooler and keeps the cabin smelling nice . No issues with the aftermarket. Save the money
Old 15th May 2010
Saaber95er's Avatar
Garage
An after market would be fine if you change it every year.
http://shop.ebay.com/i.html?_nkw=saa...=1&_from=&_ipg=
Old 15th May 2010
Default Probably long gone..........
Saab stopped selling the two filters as a service part back in 2001. The carbon filter was a mesh bag of granules that slid into a plastic rack located adjacent to the thin pleated filter.
In order to fit the thicker new style filter the plastic rack needs to be removed. The only means to do this is to grab it with your hands, break it apart, and yank it out.
I am sure your car has already had this done.
Old 24th July 2010
skmaxwell skmaxwell is offline
My Saabs: 2003 Saab 9-5 Linear
I just replaced my cabin air filter for the first time today, which was much more difficult than I thought it would be. Especially since the aftermarket filter I used had the "air flow this way" arrow reversed--beware of this! And the new aftermarket filter definitely did not look nearly as good of quality as the old genuine filter I pulled out--although it was much cleaner than the old one! I don't think the previous owner had ever changed it, and I bought the car at 52k miles.
Old 16th September 2013
mrlonnybrooks mrlonnybrooks is offline
My Saabs: 1997 Saab Aero 9000
Smile 1997 Saab Aero 9000 my cabin air filter
Current prices are:
Aftermarket - $22
SAAB OEM - $54
$11.80 www.rockauto.com
I bought my saab used and bought all new plugs/plug wires/filters/serpentine belt/filters(air/cabin/fuel) under $150 for everything to me this is cheap insurance
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
