Lets replace the Coolant Temp Sensor 4cyl petrol engine - SaabCentral Forums
Old 7th June 2009
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Default Lets replace the Coolant Temp Sensor 4cyl petrol engine
Symptom:
Temp guage drops to nothing, solid check engine light on, coolant level fine, car drives fine.
Tools:
Deep 19mm socket and ratchet or 19mm ring spanner
Approx 1 litre coolant
Part:
Coolant Temp Sensor: PN 15393755
Procedure:
  • Release pressure from coolant exp tank, then refit the cap
  • Locate sensor
  • Detach electrical connector
  • Un bolt sensor (its tight) and refit new one
  • Replace connector
  • Top up coolant
  • Run engine with coolant reservoir cap OFF and check for leaks around the sensor
  • Ensure thermostat open and fans cut in (air con off)
  • Top up coolant if required
  • Replace reservior cap
  • Drive car, then check levels
Old 7th June 2009
Bubbaman's Avatar
Bubbaman Bubbaman is offline
My Saabs: MY01 9-5 Aero Sedan (T7Suited St 2+) LPG
And don't drop the new sensor on the gearbox like i did..... VERY hard to get it out of there!
Chris: PITA to get the socket on! Very little working space between the battery and fuse box to wrench
Old 27th July 2009
ajaiello85 ajaiello85 is offline
My Saabs: 2003 saab 9-5 linear(rip), 2006 9-5
regarding the step in which you unplug the connector....does it just pull straight our from the sensor? i was looking around and tryin tinker with mine last night, but wasnt able to disconnect it =/. thanks in advance guys
Old 27th July 2009
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
There is a picture in the post showing how you squeeze the blue connector and then pull it out.
Old 27th July 2009
Carson89's Avatar
Carson89 Carson89 is offline
My Saabs: 03 9-3SS Aero
Garage
Ha, I replaced mine just this weekend. Took not more than 3 minutes to complete and I lost no more than 1/4 litre of coolant
Its definitely not the easiest part to get at. Socket or spanner, its still a pain.
Old 24th January 2010
fusionrx fusionrx is offline
My Saabs: 07 Honda Odyssey no saabs
Don't know how you guys get your hands in there!
Not a chance that I can get anywhere close to the parts with my gigantic mitts.
In an attempt to do this and the thermostat, I can't get my hands in either place...
No more Saab repair bills for me...
rcase13 rcase13 is offline
My Saabs: 2003 9-5 SportWagon Linear
Just replaced both my coolant temp sensor and thermostat. Easy in principle but if you have large hands it's a pain and I probably have scars for life on my hand!
themuffhead's Avatar
themuffhead themuffhead is offline
My Saabs: 2002 9-5 Aero Wagon
I'm wondering why this part seems to fail on every saab.
Never seen it go out on chevorlet or honda.
Old 11th February 2010
elizann73's Avatar
elizann73 elizann73 is offline
My Saabs: 2003 9-3SE Convertible
Lightbulb
THANK YOu SOOOOOOO MUCH FOR THIS POST!!! I just found out today that I need to replace mine. Looks pretty easy, except for the small area part, lol. And I was amazed at the cost!
Is this a part that would cause something else to go that should be changed at the same time? ie-thermostat?
Thanks again!! You ROCK!
Old 13th February 2010
dsljay dsljay is offline
My Saabs: 1999 9-5SE
How much does this part cost? I just got a price quote of $85.00US. ouch!
Your friend, Jay
2002 9-5 Aero 186 (grandsons)
2006 9-5 sport combi 79K (my sons)
1999 9-5SE 192K (gone but not forgotten)
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Not much:
http://www.thesaabsite.com/900new/ng...ERATURE+SENSOR
Old 3rd March 2010
saabfire's Avatar
saabfire saabfire is offline
My Saabs: 99' 9-5 SE
There's only one sensor right? I thought I read somewhere that there were 2. One for the gauge and one for the ECM.
Old 4th March 2010
elizann73's Avatar
I have been told since changing mine that there are 2 but of all the places I called to get the part not once was I asked "which one". I changed mine a few weeks ago, had it reset and its still doing it. The guage drops to nothing and the engine light is on. Is it possible the brand is the reason? The brand I ended up with was a Bog Warner(sp?).
Thanks ) I'm also going to check the plug itself and make sure its all clean and wires are tight.
Old 19th March 2010
Chris,thanks for the good write-up and photos. I couldn't get my old hands in that small area, so I removed the battery and used a deep 19mm socket and a 3 inch extention. Job done. Thanks again for the photos, they really helped. Jay
Your friend, Jay
Old 20th March 2010
RGG RGG is offline
My Saabs: 9-5 Aero 2003
[QUOTE=elizann73;1718808]The guage drops to nothing and the engine light is on. Is it possible the brand is the reason? The brand I ended up with was a Bog Warner(sp?).
See where I worked through a similar issue. https://www.saabcentral.com/forums/sh...d.php?t=179814
If that gauge is normally working then drops to zero after about 15 minutes of driving, then comes right back after turning off the engine and restarting... change the thermo when you replace the sensor.
Old 20th March 2010
Jssaab Jssaab is offline
My Saabs: 2003 Aero Hirsch "Clone"
[QUOTE=RGG;1730126]
Yeah Chris, this is more common from the Thermostat not a sensor issue. It is used to indicate the car is not getting to operating temp
Old 22nd March 2010
rhcoleman rhcoleman is offline
My Saabs: 2003 9 5 Linear; 2007 SportCombi
This thread was so very helpful and lucky timing for me. Thanks to all. I have been having the occasional 'drop to zero + not fully warming up' symptoms indicating new thermo needed, but today I got a CEL as well. Telling myself not to panic (I have had some painful recent Benz experiences), I went to this forum and ,,, there it was! The answer to my problem. I have ordered a thermo, sensor, and sealing ring and think I will do no real damage driving my 95 until the parts arrive. When I do the repair, I will need to reset the CEL, correct? And I think I do that by pulling a fuse, # 12 I think?
Old 22nd March 2010
RGG RGG is offline
I don't know which fuse though I read it on hear somewhere.
On the 4 (don't know about the 6), there is a ground line attached to the thermo housing. As I had to clear the CEL and I'm over cautious when dealing with electrical, I just pulled the negative battery wire.
Old 10th September 2010
Mr. Underhill Mr. Underhill is offline
My Saabs: 2002 Saab 9-3 SE CNV (silver)
Default Spanner
You mentioned 19mm Spanner... and someone in another thread mentioned to use a 19mm dog-legged spanner... you wouldn't happen to have a pic of what this tool looks like? I went to the local nappa and pepboys in town and each store rep looked at me like I was speaking jibberish when I mentioned spanner and "dog-legged" spanner. For context... I am trying to replace my coolant temp sensor and thermostat.
thanks
Old 11th September 2010
StevenS StevenS is offline
Spanner in English = wrench in American!!
I've just changed my sensor and I found a ring spanner worked fine.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
