Cabin Filter: REPLACING IT? - SaabCentral Forums
Old 22nd December 2007
bmxfratboy bmxfratboy is offline
My Saabs: 9-5
Default Cabin Filter: REPLACING IT?
I checked the FAQs, how do you replace your cabin filter? and are they reusable or washable, i assume not since there is charcoal in them
Zak
MI-Roger MI-Roger is offline
My Saabs: '08 9-5 Aero, '06 9-3SC, '00 Viggen
Default Replacing Cabin Filter
Six steps:
  1. Remove the squarish carpeted cover on the side of the tunnel hump in the passenger footwell. To remove it you depress the center pin of the 3 plastic rivets approximately 1/8-inch with the tip of a phillips screwdriver.
  2. Remove the knee panel below the glove box. Look below the glove box hinge and you will see a row of 3 or 4 screws, remove these. The front edge of the knee panel is held to the firewall by a nylon grip. Pry the two fingers of the grip apart and slide the panel straight rearward towards the passenger seat to remove. Trickier to do than it sounds.
  3. Remove the glove box. With the knee panel removed you will see a new row of screws beneath the glove box hinge, remove these. Open the glove box and remove the row of screws along the top edge of the glove box. Slide the glove box half-way out of the dash, remove the electrical wires powering the light, remove the hose which sends cold air to refrigerate the glove box, then slide the box out fully.
  4. Remove the side cover of the HVAC box which sits atop the tunnel hump. There are approx 10 small (6mm?) hex screws which secure this cover. A coil-spring style of flexible socket adapter really helps here.
  5. Slide the old filter out of the heater box and discard. Pull out the foam strip above the filter and discard too. Install new filter and new foam strip which came with it.
  6. Replace all parts in reverse order.
I am assuming your car is not a 1999 or early 2000 which still has the factory original filter. If I am wrong, then step #5 has to be changed slightly. But with 2008 only a week or so away, I think my assumption is safe.
Have fun! Plan on allowing 45 minutes to replace the filter your first time.
Default Revised Step #5
Well, I checked your previous posts and see you do own a 1999 model. Chances are someone before you has replaced the original factory filter, but just in case, the revised instruction step is below.
5. If you have a single pleated filter, discard it with its foam sealing strip and install the new parts. If you have two filters (a thin pleated filter and a mesh bag filled with activated charcoal crystals) then you will need to remove both filters AND the plastic rack which held the mesh bag. The only way to remove the filter rack is to break it into pieces and yank it out! There are lots of sharp edges in there, so don't cut your hand and drip blood all over your interior. With the old rack removed there is now room to install the new thicker pleated filter which is impregnated with carbon particles.
Step #6 stays the same.
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
Exclamation M-I Roger is the Man!
+1 for revised step 5.
By the way I wouldn't assume anything about cabin filters. I just changed mine this past march. Still factory as you described!
I just thought i had done something worng when I tore all of that out. And I figured I was lucky that nothing had gone wrong since then.
Here's a write up with pics - http://www.twinsaabs.com/9-5_repair/...bin_filter.asp
However - Roger is the man and repeatedly has top info. I'm still all excited about my larger oil filter!
zef95's Avatar
zef95 zef95 is offline
My Saabs: 2001 Viggen 5D, 2002 9-5 Wagon (sold)
Default Useful link
This guy has also documented a cabin filter replacement.
Old 23rd December 2007
born again born again is offline
My Saabs: 2005 9-5 AERO 5D 2.3L AT; 2008 9-3 2.0T
The filter on my '99 was also factory fit when I changed it last year. The dealers try to finance their children's college tuition from changing these. Many owners don't bother.
Old 24th December 2007
My Saabs: 9-5
yeah, mine was nasty, to say the least, there were leaves, plants, animals, even a old hermit in mine, i am so glad i got that changed,
tip: get all you can with a broom and your hand, then turn on a shop vac and get some more, then turn the ac on full bast with the vaccum on, to get what's left, then breathe easy
Zak
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
