All new suspension (with pictures, as usual) - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > 9-5 Performance, Mods & Tuning
9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9-5
Old 1st October 2007
dip's Avatar
dip dip is offline
My Saabs: -
Default All new suspension (with pictures, as usual)
Featuring five broken bolts and a mass of mangled pieces of metal, this weekend brings you... a complete chassis rebuild of my junker. Bilstein Sport shocks, Eibach springs, new strut mounts, rear Aero anti-roll bar and poly bushings everywhere.(click the above links for more pictures)
...ok, I cheated - the front bushings were done last week ;]. Booking my wheel alignment tomorrow...
SaabBlackMan's Avatar
SaabBlackMan SaabBlackMan is offline
My Saabs: 2010 Saab NG 9-5
how much did you pay for all of this and where did you buy it from?
Saab Blackmista.
bringer bringer is offline
My Saabs: 2003 Saab 9-5 Aero
Excellent post, thank you for documenting so well with pictures and details. Job is enough of pain just zipping through it so I appreciate you taking the extra time to help others.
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Oh yeah I love Dip's photo instruction series.
Did you do the front sway bar as well? Didn't see the photos on that one... is it because you tossed the camera away in disgust at how difficult that job is?
I want to hear your review of the ride quality change with stiff shocks, stiff springs, stiff bushings....
dip's Avatar
dip dip is offline
My Saabs: -
The front bar is on hold until I have a good enough reason to drop the subframe ;]
MacNoob's Avatar
It DOES make a huge difference in body roll and balanced handling, don't wait too long! Replacing the front bar is a 'good enough' reason... It took me about 4 hours or so. Start with the PB Blaster on the sway bar bushing attach bolts now. I shot mine every time I had the car on ramps for a year. Then when I went to remove them (fine thread, strong alloy bolts) I was able to slowly winkle them out. DON'T BREAK ANY. Loosen a bit, PB under the head, tighten, loosen a bit more, PB under the head, tighten.... repeat as necessary... you can reach them with 3/8" ratchet through the wheel wells. Air ratchet is super for reinstall.
About 3 feet of 3/8" drive extension is handy, so you can reach the rear engine mount bolts from up top behind the engine - you will also need a Ujoint and/or wobble sockets. You just need to disconnect the mount and steering rack - don't need to remove it.
I disconnected the downpipe at the turbo and lowered it a little too.
I removed the rear and middle subframe bolts. You just need to be able to lower the subframe an inch or two to get the bar out.
Replace the sway bar end links (Scantech, $20 ea) when you have it apart, it's too easy to damage the rubber boots on the end links when you take it apart. I've got 80k km on my Scantech links and they are still solid.
Then get a good alignment. My caster was out, it can be adjusted through shifting the subframe, so don't know if I screwed it up loosening the frame or if it was already like that.
And that's all I've got to say about that.
dip's Avatar
dip dip is offline
My Saabs: -
Thanks for the reassurance. I actually did the job a couple of times on other cars... There's only so much you can squeeze in one weekend though. I will certainly post the photos when I find the time to install the front bar.
dip's Avatar
dip dip is offline
My Saabs: -
DON'T BREAK ANY.
Actually, breaking sway bar bushing bolts is not such a disaster. You just take a cold chisel and hammer away the nuts welded to the bracket. They come off easily. And then you re-install the bar with regular bolts and nuts.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Top post!
Well done!
Kermit another one for the FAQ section please
SectorNine50's Avatar
SectorNine50 SectorNine50 is offline
My Saabs: 2000 9-5 Aero 5-Speed
Did you notice any difference after you just did the front bushings? I'm wondering if I should do this as my next suspension upgrade.
2000 9-5 Aero 5-Speed Silver/Black
Upgrades | Open Intake | Poly Trans Mount | Hub Braces | Sub-frame Brace (Broken) | Forge 007 | FMIC | Bilstein HD Dampeners | 3" CTI Cat-back
Gazolzwurf Gazolzwurf is offline
My Saabs: 9-5 Aero MY05 / 9-5 Aero MY02
Superb write up, I'll be back to read this properly when I'm not falling asleep at my desk.
ACBarnett ACBarnett is offline
so how is the ride height compared to a stock aero suspension?
I want to do a spring/strut upgrade on my aero, but the stock rige height is as low as I want it to go, otherwise I'd lose the airdam on a weekly basis around here.
Raven18940's Avatar
Raven18940 Raven18940 is offline
My Saabs: 2001 9-5 Aero 5spd
Mine (same suspension) was lowered no more than 5-10mm. Honestly I couldn't tell the difference when I saw it.
Originally Posted by VikingSpirit
We can neither confirm nor deny the rumours that there is, was or ever will be "females" or "Message Boards" on the interweb...
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: None now
Garage
Awesome writeup.... I know that I'm due for a suspention sometime in the near future which includes a polly bushing rebuild as well.
There is a "replacement for displacement".... It's called "forced induction".
Old 2nd October 2007
Does anyone notice a difference from the poly bushings? lol
yfs87's Avatar
yfs87 yfs87 is offline
if you have shot old ones then yes, it will amaze you how much difference a set of new poly bushings tighten up a cars feel.
On the road:
90 c900T16 cabriolet - red
91 c900spg - red
79 Porsche 911SC - red
Projects:
92 c900s 4dr - blue (on the backburner)
RIP:
93' c900s (drunk driver hit it)
90' c900s (deer found it attractive)
89' c900T (Friend crashed it)
88' c900T (parted)
87' c900T (parted)
89' c900s (parted)
hambone575 hambone575 is offline
My Saabs: 9-5 Aero Wagon
Heres a quick stupid question... How long should the stock aero suspension last? Bushings etc
Old 16th January 2008
2WhiteSaabs's Avatar
2WhiteSaabs 2WhiteSaabs is offline
My Saabs: '04 9-3 ARC & '00 9-5 SE "Olie"
Fantastic post! Just in time as well. Question: my passenger rear tire is cupped to hell, it is almost octagonal. Looking at the suspension, the shock has a very faint hint of leaking fluid but thats all. The spring, when compared to the one on the driver side, is slightly curved and the drivers side one isn't. How do determine if I need to replace the shock and spring or just one or the other? Budget is an issue.
"All moronic statements can be attributed to ignorance, not apathy, and will correct themselves over time. Please stay tuned." - S.W.D.
stipud's Avatar
stipud stipud is offline
My Saabs: 1999 9-5 2.3lpt Auto Nordic Stg. 3+
Garage
The rear shocks are a frequent failure item, while springs are very rare. I'd bet all of my POGs on shocks. You should consider replacing them with an aftermarket setup like Bilstein HD, Koni or KYB, as they should last much longer.
Tuning:
Stereo:
valrune valrune is offline
My Saabs: 00 95 2.3 5sp
Where is the best place to purchase these items? I'm considering this upgrade for my 2000 in the near future! Thanks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
