Power Steering Line - SaabCentral Forums
Old 5 Days Ago
sleepinSaab's Avatar
sleepinSaab sleepinSaab is offline
My Saabs: 06 9-3 2.0T
Default Power Steering Line
I've got a nasty power steering leak. I'm going through roughly a quart of fluid a week. I'm assuming its a high pressure line because of the amount of fluid lost. From the research I've done so far, the line that runs around the front of the car is the usual suspect, however I have fluid puddling on the frame rails by the fire wall and under the rack on the drivers side. Anyone have an idea of which hose it is, or what part number? The diagram on the eSaabParts site is kind of wonky to follow. My guess would be #12 in the link below. Thanks in advance.
https://www.esaabparts.com/viewparts.php?searchpart=1&section=462059736
Old 5 Days Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
My Saabs: None at the moment
I'd bet its the return line from the rack to reservoir (while its not under the same pressure as the pre rack line, its still under significant pressure and will quickly lose fluid).
I find the end of the hose goes hard and cracks that along with the clamp rusting and loosening leads to a significant leak.
I normally just cut off the last inch of the line and reinstall with a new hose clamp, that should take care of it, you can replace the whole line, you'll want to order one specific to that application since the hose is a molded and a different diameter at each end.
Old 5 Days Ago
hiloh_3 hiloh_3 is offline
My Saabs: 1999 9 3 SE
Might be where the leak is although in my 99 the hose wore out upon the passenger side of the radiator here it as rubbing against the frame. it sprayed everywhere. Is your serpentine belt wet? I think you have a 2006 9 3? If so, the hose you are looking at would seemto be the wrong part number. If you can download Saab EPS you can put your model in and comeup with the right part number. Alternatively you should be able to go to ESaab parts, Eeuro Parts or FCP euro and put in your VIN number to get the right part #. Here is a link for where to get WIS and EPS: http://saabworld.net/showthread.php?t=33310
Old 5 Days Ago
I haven't updated my bio yet but I have an 02 9-3 SE. Initially thought it was a return line since it continues to drip when parked but it has since gotten worse. I'll try to get it up in the air. I hope its just the return and not a pressure hose.
Old 5 Days Ago
I'll give the belt a look as well but last time I cleaned the engine bay (last week) I did not see any wetness to any of the belts.
Old 5 Days Ago
Ah, that explains it. I looked it up in EPS and that is the right part number. Jake's point about cutting the hose a bit is a good one that worked for me once but if you do order the paart new ( a wee bit pricey)don't forget the o ring on the other end.
Old 4 Days Ago
BobSaabit's Avatar
BobSaabit BobSaabit is offline
My Saabs: '03 9 'vert; '01 9 5d & parts car;
I give high odds it’s Jakes solution you need. I put this off for a long time during the winter because I thought it was the real high pressure line back there and that looked like a major PITA outside in the winter. So I wasted lots of money on overpriced chf 11 & 202. All I needed was this repair.
The good news is that my PS fluid is flushed to new status.
Remove the strut bar. Loosen the fuse box and pull it out of the way. Remove clamp, cut hose, re-clamp. Replace removed stuff. Done.
Old 4 Days Ago
I'll get a look at the return line today hopefully. I guess it can't hurt to start with the free/cheap fix first.
Power steering line under radiator- whats involved in replacing? tuftyboy NG900 & OG9-3 Workshop 14 4th November 2017 02:35 PM
Power Steering Line Replacement Part 1 WireGuy1950 NG900 & OG9-3 Workshop 27 23rd June 2016 06:33 PM
Power steering line p5p NG900 & OG9-3 Workshop 10 29th September 2015 10:47 AM
Power steering line p5p NG900 & OG9-3 Workshop 0 27th September 2015 09:23 AM
Power steering line finally finished marinekilz NG900 & OG9-3 Workshop 2 13th March 2011 12:32 PM
