"ready" monitors on tech 2 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Tech II Workshop
Tech II Workshop For all discussions regarding the Tech II onboard diagnostics tool.
Old 3 Weeks Ago
redaero-wagon-2000 redaero-wagon-2000 is offline
My Saabs: 2003 95 Aero, 2001 95 Aero, 2000 Aero 5d
Default "ready" monitors on tech 2
Is there a way to read the OBD 2 readiness monitors with a tech 2 ?
I have to smog my 2000 Aero in CA and I would just like to check it first.
Old 3 Weeks Ago
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: Hirsch fleet: 2*9-5 + 9-3
Nope. Only TECH2 or OpenSID.
Old 3 Weeks Ago
Tboy's Avatar
Tboy Tboy is offline
My Saabs: 94 900SE V6, 2000 9-5 Aero mt
I think he asked WITH a tech 2. He is looking for info on how it is done with tech 2.
1994 NG900 V6 >
2000 9-5 Aero mt
Old 3 Weeks Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
I don't know the answer to that, however just about any ODB II reader will show the status of the different monitors. So I would take it to one of the shops that read it for free and ask.
If there hasn't been a trouble code, and the battery hasn't been disconnected recently (maybe a week or two), you should be OK. It does take a long time, if just using the car normally, for the CAT monitor to complete.
Old 3 Weeks Ago
THANKS. I do have a Tech 2 as you stated and open SID.
So I am just wondering if it can read the specific readiness.
I have a Durametic piece of software for my Boxster and It has a specific readiness menu that tells you whether it passes or fails.
I think I am ok with smogging my 2000 Aero as I have no CELs and I drive it regularly.
Old 3 Weeks Ago
I have Tech 2 and OpenSID so how to I read readiness??
Old 3 Weeks Ago
Mimmi's Avatar
With TECH2, use live monitor and select O2 and you have vector diagram.
With OpenSID, you have to write manually all readings.
Old 3 Weeks Ago
and how do I know what the passing readings are? or am I missing somethiing here?
The California smog check station says PASS FAIL and not readings. They do not even run the engine, just plug into the OBD2
Old 2 Weeks Ago
EdT EdT is offline
Honestly, if you can't figure it out on the Tech II, go to any parts store that does code reading and see what they say. As far as I can tell, monitor readiness status is down at the most basic level of functionality of ODB-II readers.
But, like I said, if you haven't had any Check Engine lights for a while, and the battery has remained connected, you should be fine. A couple of months with no light or battery/ECU disconnect should be a slam dunk.
Old 2 Weeks Ago
I must have the wrong OBD 2 readers I have never seen monitor readiness in the ones I own.
Old 2 Weeks Ago
EdT EdT is offline
Huh.
I bought a pretty good reader (Innova 3040 more or less) back in 2011 when I got my 900. It sums up monitor readiness via LEDs and also displays which ones are still pending.
The cheapest Innova sold by autozone has monitor status, though I don't know if it tells you which ones might be pending: https://www.autozone.com/test-scan-a...ors/273349_0_0
I'm sure that someone with better online shopping knowledge could find cheaper knockoffs with this technology.
ODB II readers remain some amazingly overpriced electronics considering their commodity nature. They should be like $20 instead of $200 for a pretty good set of features. It's not like the ODB II standard keeps getting updated by Apple or anything.
Old 2 Weeks Ago
jvanabra jvanabra is offline
My Saabs: LOTS. :)
IIRC, readiness monitors are shown in the OBDII section, not in the deeper tool.
Old 2 Weeks Ago
EdT EdT is offline
I couldn't find any place in Tech II where readiness monitors are found. I assume my car is 100% ready....but my ODB II reader is elsewhere at the moment.
HTML code is On
96 9000 CSE - OBD procedural/emissions checklist saabreyhepburn 9000 Workshop 3 13th May 2017 01:31 AM
Does Tech 2 read a history of faults? RemoGaggi 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 12 11th August 2016 12:18 PM
Tech 2 Freezes at Post plowester Tech II Workshop 0 21st November 2014 08:21 PM
"not ready" sensors harrisonbergeron NG900 & OG9-3 Workshop 4 2nd April 2009 03:14 PM
Tech II stuff JMarkert 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 35 26th February 2008 02:08 PM
