Removing the door panel - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-2X, 9-4X & 9-7X Workshop > Saab 9-2X, 9-4X & 9-7X Workshop
Old 10th March 2019
mikeva mikeva is offline
My Saabs: '00 9-3 Viggen, '11 9-4X Premium
Default Removing the door panel
Hey folks, has anyone managed to remove the door panel on one of these? I need to take a look at the window regulator, but I'm not sure how to get at the screws behind the door handle. I saw the post about "Replacing the door speakers", but not super sure about which trim piece is supposed to pop off. I'm assuming it's the outer-most wood looking piece (Premium trim). I can separate it a little bit around the inner edge, but nothing's popping. The outer edge isn't giving at all and it's tucked under the leather at the two ends. A little worried I'm missing something so any tips appreciated. Thanks!
Old 12th March 2019
JBarstad JBarstad is offline
My Saabs: 05 93Lnr 09 93Aero XWD 11 94XAero
You're on the right track with the piece you're referring to. I have typically started out near where you would normally grab the handle to pull the door closed. It's on there really well with a bunch of spring clips, but it does come off.
I pointed out the piece that comes off with a black arrow. If I remember correctly, there is also a screw up where I put the red arrow.
Good luck!
Old 13th March 2019
Excellent! I'll give it another shot tomorrow night and see how it goes. Thanks!
Old 14th March 2019
I think the sides, and bottom of the panel are all help on with pressure clips, so you can pry the sides, and bottom off, then the panel lifts off the top of the window sill basically. Pretty typical, but if it's your first time, you always wonder what the next step is.
I hate interior trim. Always worried all the stupid little plastic clips are going to explode everywhere.
Old 14th March 2019
Joshinator99's Avatar
Joshinator99 Joshinator99 is offline
My Saabs: None
This! I’m paranoid that I’ll break or crack a plastic piece, scuff it up, or otherwise mess it up. Ugh...
2017 Chevy Camaro SS A8 Whipple supercharger, 95mm TB, 5” CAI, 608 RWHP/610 RWTQ
2019 Toyota Sequoia Limited A6 5.7L V8, 381 HP, 4WD, 20” wheels. Daily driver.
2018 Alfa Romeo Giulia Ti Sport Q4 A9 AWD, Carbon fiber DS, adaptive suspension, 19’s.
Past Saabs: ‘11 9-5 Aero XWD 370 HP, (2) ‘11 9-5 T4P Java, ‘06 9-7X 5.3i, ‘72 Sonett
Old 14th March 2019
Spot on! I found it easiest to get a tool in around where the window switch is. Then I worked toward that area where the handle is as you suggested. The clips there were super sturdy, but once I got those out I was able to work back toward the two ends without trouble.
There's a little pry gap hidden by the lock release, but that was no trouble at all. After the bolts were out, the rest was like videos I've seen of the SRX!
About missing by-pass valve; removing coolant hoses;rad¯? finbarr C900 Workshop 2 28th August 2007 05:28 AM
Removing balance chain bentech NG900 & OG9-3 Workshop 13 2nd March 2007 11:58 AM
Need Help removing fuel line. clarrichard NG900 & OG9-3 Workshop 7 6th December 2006 12:07 AM
front panel removing vitalspec NG900 & OG9-3 Workshop 0 20th May 2006 05:01 AM
Removing oil sump lowrider02446 9-5 Workshop 3 22nd February 2004 10:58 PM
