Correct O2 sensor fixed check engine light but now slower??! - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Performance, Mods & Tuning
9000 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9000
Old 30th May 2012
j006's Avatar
j006 j006 is offline
My Saabs: 2003 9⁵ Aero 5spd | 1997 9000 Aero
Garage
Default Correct O2 sensor fixed check engine light but now slower??!
Alright gentlemen, some of you may know I've been sorting issues on my new-to-me-Aero, which was all Abbotted out when I got it, ECU included. I went from being stuck in base boost and a check engine light (O2 Sensor issue) to realizing the full potential of the hardware and software upgrades. The wastegate rod clip was missing, the spark plugs were all fouled because they were too cold a plug, the BPC valve was dead, and the pcv check valve was missing among the issues. Cheers to all who helped directly or posted in the past to help!
Fast forward to last week: Under full throttle the boost gauge pins several clicks past the end of the red and off we go! The boost comes fast and strong, but I still had that pesky check engine light until a couple days ago. The previous owner had installed a universal type O2 sensor and spliced it in, so it was very suspect. Over the weekend I installed the proper Bosch O2 sensor, reset the ECU and no more check engine light since! Great success! The only issue is that although the boost delivery is much smoother and the engine seems to run generally better, the 'butt dyno' tells me is that it's a tad slower. Under full throttle now, the turbo needle only goes slightly past the red zone, and I really have to work to get it there. Maybe I need to do an adaptation run? What's your thoughts guys?
Cheers!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
Very poor gas Mileage, Check engine light...(FIXED!!!) HIX C900 Workshop 9 1st October 2010 09:05 PM
CPS fixed - check engine light still on Irishluck002 9-5 Workshop 4 20th August 2010 01:16 PM
Check Engine Light on after replacing the O2 sensor Burj900S C900 Workshop 0 1st March 2009 11:06 AM
Sun Sensor and check engine light khtheosfan 9000 Workshop 2 2nd October 2008 07:50 PM
O2 Sensor/Check Engine Light MrGBFAN C900 Workshop 2 12th June 2002 02:44 PM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
