PCV Update Kit #6 Question - SaabCentral Forums
Old 10th June 2019
Paragon Paragon is offline
My Saabs: 9-5 2.0t ARC Sport Wagon
Lightbulb PCV Update Kit #6 Question
Hi guys,
It's been a while since I've posted here, but I'm still the proud owner of a 250,000 mile Saab 9-5.
I want to do the PCV Upgrade on my own, however, I am a bit confused as to what parts I require. The car and engine are a 2002, I don't think it has any update to the PCV system.
To my understanding, I need the PCV Update #6 that has the part number: 55561200. Do I need anything else?
I'm asking as I've seen plenty of kits named "PCV Update #6" that are either priced at around $50 and some that are priced at $80. Which one do I need?
Thanks!
Old 10th June 2019
hunterstein555 hunterstein555 is offline
My Saabs: 2002 9-5, 1999 9-3 vert
I'm not sure about the price differences but you need this:
https://www.genuinesaab.com/catalog/...roducts_id=456
Everything in that picture is what you need
Old 10th June 2019
Thanks for the reply!
In the genuinesaab.com link, the 55561200 part number appears. However I've seen this PCV Update #6 kit with the part number 55554444, called "Complete kit", and looks like this:
This is why I'm confused about this kit.
Old 10th June 2019
Hmm, that is weird. Looks like it additionally includes zip ties, crankcase breather hose, check valve, and another one I can't recognize. Not sure. I'm sure someone else has some better advice
Old 10th June 2019
Mariner Mariner is offline
My Saabs: 2006 SC #1 , 2006 SC #2
If I had a 9-5 of your vintage and with 250,000 miles I would use this "complete kit". I would drop the oil pan first, and make sure it is clean and free from sludge. I would use the full kit because the "extra" parts have been exposed to heat and stress for 17 years and many miles. The difference in cost is small compared to cost to replace the engine.
Mariner
2006 9-5T SC #1; 2006 9-5T SC #2
Old 10th June 2019
What year is your car? I don't recognize the '2.0t sportcombi' as a 9-5
Old 11th June 2019
The pan has already been dropped, the shop guys told me it had some sludge but not an exaggerated amount. Since then, I've driven the car perhaps, 400km. The oil used is GM 5W30.
Old 11th June 2019
The "2.0t sportcombi" is also called the 2.0t ARC Wagon. It's just a standard 2002 Arc 9-5. the "sportcombi" is just some name used in Sweden if the car has some optional extras. Or at least this is how I understood it from the paperwork.
Old 11th June 2019
Gotcha, I didn't know any 9-5's, at least the somewhat older ones, came without the 2.3
Old 11th June 2019
Yes, the petrol 9-5s came with both the 2.0 and the 2.3 engines. Depends on the version and the optional extras.
Old 11th June 2019
andybisnut andybisnut is offline
My Saabs: 2006 9-5 SportCombi 2.3T
Maybe I'm the only one who feels this way, but if you've made it to 250,000 miles, and the pan has been recently dropped and is fairly clean, I'd just leave it alone....
Old 11th June 2019
Hi andybisnut,
That is true, if the engine survived 250,000 miles with the original PCV system, then it seems that it's a reliable and strong example. However, the shop advised me to have the updated PCV installed, given that they found the crank bearings to be worn when they took the oil pan out.
Old 11th June 2019
If you're on time with your oil changes you don't really need it. If $80 and dirty hands is worth the peace of mind then go for it. I would personally do it if you plan on investing more money in to the car in the future
Old 11th June 2019
Well, in this case, I can ask you this. I don't drive the car that much, perhaps 1000km per year so far, when should I change my oil? To give you some perspective, the oil changed almost a year ago, with the oil sump drop is still clear and brand new.
Old 11th June 2019
1000 km per year, wow that's low
I'd say once every 6 months, but probably once every year, provided that you drive it evenly (as in, once every two weeks, as opposed to letting it sit for 9 months and then doing 1000 km in the last 3 months)
For the record, the cars make their most sludge in stop-and-go city driving
Old 11th June 2019
Unfortunately, it mostly sits undriven for months, and then I drive it 500 km in two months, then sits again. It's not ideal, but it's what it is.
Old 11th June 2019
I don't think you have too much to worry about but I don't know much about oil breakdown
Old 11th June 2019
I see, most likely I will change the oil before Christmas. I saved this 9-5 from becoming either a scrap car or a parts car. I'll never sell it, but the current situation prevents me from driving it daily.
At least, it doesn't rust when sitting in it's parking spot.
Old 11th June 2019
I don't think we got the 2.0 in the U.S. on the 9-5, but I definitely see other forum guys outside the U.S. with them. I wonder how it compares to the 2.3?
Old 11th June 2019
It's slower, mine only has 150BHP and uses the standard 5 speed manual transmission.
The 2.0 and the 2.3, or better called the B205 and the B235 are essentially the same engine, just the inner displacement and turbochargers used are different.
