MAF flow rate - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > 9-5 Performance, Mods & Tuning
9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9-5
Old 29th August 2018
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2005 SAAB 9-5 Aero fully loaded
Default MAF flow rate
I was running my OBD II adapter and Torque Pro today just looking at some numbers.
Is a MAF flow rate of 171.7 g/s pretty standard for an '05 Aero?
Boost was 17.8 Psi and Intake was 31.8 Psi.
40-60 Mph was 2.6 sec (kick down with the auto in Sport mode).
I know in the 9-3ss forum someone had put what the stock MAF g/s max flow rate was (I don't recall what the number was though) but I haven't seen what it is for the 9-5's so figured I'd post and let others chime in.
I posted in here because I figured that this info would be more geared to the tuning side of things than the workshop side of things.
2004 9-3 Linear Fully Loaded - R.I.P July 28 2015
2005 Saab 9-5 Aero Fully loaded
Old 31st August 2018
Nocturne's Avatar
I guess nobody knows?
The search continues...
Old 1st September 2018
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: Hirsch fleet: 2*9-5 + 9-3
How much milligrams/combustion that weird g/s would be?
CdnSaab95 CdnSaab95 is offline
My Saabs: 2007 Saab 9-5
How much information does the torque app show? I wanted to get open SID but it's too complicated for me.
Sent from my iPhone using Tapatalk
Llwrider_rt2000's Avatar
Llwrider_rt2000 Llwrider_rt2000 is offline
My Saabs: 2005 Saab 9-3t
It will show maf flow rate and everything else you want or need. I have the paid version. Well worth it!
Sent from my 9-3
Sent from my 9-3
Does it matter which obd2 dongle you have? I see there's blue driver for $100 and another one for $26. Do they both read the same thing for the Saab TRIonic system?
I paid $25 on eBay for mine
Sent from my 9-3
Old 2nd September 2018
Nocturne's Avatar
171 grams per second.
I'm just curious as to what the stock flow rate should be.
I can change the readout to psi I think if that would make more sense. I recall in the 9-3ss forum they always talked about grams per second. I think it was 125 grams per second was stock flow rate. I could be off on that number though. Basically, they were saying if you were tuned, your flow rate would be higher than that. And if it was below that you should clean the MAF and replace the air filter. I just don't know what the flow rate should be on a 9-5 aero.
Nocturne's Avatar
It will show any data available from the ECU using the OBD protocol. Things like transmission temp aren't run through OBD so you won't see that. But there's still a ton of info through OBD.
Emissions readiness, 02 sensor voltages, cat temp, coolant temp, manifold pressure, boost level, etc etc.
Old 3rd September 2018
Mimmi's Avatar
I never looked that value, only milligrams/combustion.
Grams per second is not right in itself, because it depends on the RPM.
Old 4th September 2018
Nocturne's Avatar
Actually, I found a formula that checks out by using the grams per second.
Grams per second x 1.28 = whp.
So, 171 x 1.28 = 218 whp.
Add 15% for drivetrain loss (auto tranny) = 250 at the crank.
It refelcts what people had gotten at the dyno so there is good use for grams per second.
Old 19th September 2018
I'm going to try this formula today 🤔
Sent from my 9-3
Old 21st September 2018
Nocturne's Avatar
Sent from my 9-3
How did you make out?
Well....my Torque App said my MAF at one point was 193.6 g/s so times that by the 1.28 and I got 247.808 hp.
Sent from my 9-3
Nocturne's Avatar
Sent from my 9-3
Linear? Are you stock or tuned? Auto or manual?
It's an 05 9-3 Arc 5 speed manual. Stage 2 tune
Sent from my 9-3
Nocturne's Avatar
Sent from my 9-3
I'd say it pretty much checks out then. If you said stock, I'd be like, dammit! Gotta find a new formula. But stage 2 on an Arc, ya, it's pretty in line with those numbers I think.
Old 9th April 2019
Nordic-Machine's Avatar
Nordic-Machine Nordic-Machine is offline
My Saabs: 2008 9-3 SS Linear
How does this formula check out though?
I've got a reading of ~ 1200 mg/c on esid for the 9-3 ss linear. 1200 mg/c = 240 g/s x 1.28 = 307.2 - 15% = 261.12
Therefore I'm getting 307.2hp crank and 261.12whp..? On a stage 1! @@
Old 9th April 2019
Nocturne's Avatar
I don't know what 1200 mg/c is, so can't help with that formula conversion.
And is that from the MAF?
Old 9th April 2019
It's from air mass.
Flow Rate of these Injectors? prophetnite C900 Workshop 0 13th October 2008 03:36 AM
swap 9000 MAF for 9-5 MAF?? mattweasel 9000 Workshop 3 25th September 2008 08:47 PM
Flow rate of stock 2.0T intercooler? Frosty288 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 20th January 2008 09:03 PM
Flow rate for stock fuel injectors? mbodo 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 24th January 2007 04:59 AM
Injector Flow rate RZconvertible 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 11th June 2006 01:25 PM
