P1312 and P1334 Error Codes - Page 2 - SaabCentral Forums
Closed Thread
Old 19th June 2011
Stoicfate's Avatar
Stoicfate Stoicfate is offline
My Saabs: 2006 BMW 330i 02&03 Saab 9-5 2.3t R.I.P
I'm barely learning, but I think we aren't suppose to use the iridium ones, not positive though
Quick reply to this message
Old 19th June 2011
sakpase sakpase is offline
My Saabs: 2003 9-3 Vector 6 speed
Originally Posted by justinsaab View Post
Did you check with Saab to see if the DIC Recall applies to your vehicle and had ever been performed?
no i didn't how do i do that. and i changed the engine about a year ago would that be a problem or nah?
  #23
Old 19th June 2011
bob3000's Avatar
bob3000 bob3000 is offline
My Saabs: 2000 9-5 AERO 5spd man MPS STG2
Originally Posted by sakpase View Post
Parts for this car is too expensive man
$265 for a part that can last 10 years or more isn't all that out of line.
You have a 9-3, what engine?
Call a dealership with your year, model and serial number. They will tell you if the recall applies to your car. No harm in asking.
  #24
Old 19th June 2011
i have a B205R engine the 8th of the vin is K that engine is expensive man every junk yard i called want $2500 for it. the old one that i removed due to sludge from the car i was planning on rebuild it, because this one is leaking little bit of oil under the head. or should i swap it with a better engine?? Any ideas??
  #25
Old 17th May 2016
wbermudez wbermudez is offline
My Saabs: 2000 9-5 AERO / 2004 9-3 AERO CVT
Default T7 dic - tk3.7 55559955
Looking to replace DIC to eliminate 1312/340 and 1334 DTC's
Is this new version (TK3.7 55559955) OK to use?
Is it rated better than the orig 2000 DIC?
My ride - 2000 9-5 AERO
  #26
Old 17th May 2016
TankTak TankTak is offline
My Saabs: Elskerinne..'02 Saab 9-5 HBSaabs stage 3
TK3.7 is what matters the most as its the current model that superseded the older design. they also last longer than the previous models. regardless what it is make sure you get a SEM unit as many aftermarket ones do not last
  #27
Old 17th May 2016
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: Hirsch fleet: 2*9-5 + 9-3
Original DI casette is also made by SEM (Sweden), Aftermarket SEM casette is made in China.
  #28
Old 11th August 2017
gushertz gushertz is offline
My Saabs: 2001 9-5
Default 2001 9-5 1312 and 1334 error codes.
2001 9-5: 1312 and 1334 error codes.
Got the codes. So I read all the threads about replacing the DCI, but before I ordered the part, I replaced all four plugs gapped to .040.
After three engine starts, the light went away.
So....before you plunk down the bucks for the expensive part, try spark plugs.
I found the DCI for sale at am-autoparts for $89. I haven't had to order it (yet?). Google "2001 Saab 9-5 Ignition Coil Pack L4 2.3L Turbo AM-11957972"
I only got 100,000 miles from the plugs before the light/codes came on!
Maybe the new ones will go another 100,000?
  #29
swisssaabist's Avatar
swisssaabist swisssaabist is offline
My Saabs: 9-5 ARC estate 2002 2 t auto B205E
Please don't buy cheap **** DIC only OEM SEM has the right specs or you're will be disappointed very quickly.
most of peoples have been changed their plugs before buying a new DIC and it doesn't resolve the issue, lots of, too needed their cars towed from middle of nowhere, before claiming victory, drive for a while I'll bet you come back for the DIC again. I hope not but for sure that's the next issue. even the plugs needed to be from the right brand and right specs.
that's the vital part of that car and foolish with that means you to have several more pricey issues, like cat malfunction,even destroyed, etc
To All Sorry if my english isn't so good, Try to do my best to learn every day.
  #30
My Saabs: 2001 9-5
To each his own. That's the joy of maintaining one's own vehicle. You get to do it your way!
My experience has been generally the opposite. I've had excellent luck with aftermarket suppliers. The OEM parts fail, but the aftermarket parts keep on ticking at a fraction of the OEM parts' cost.
When I had to have the alarm battery replaced, aftermarket was much cheaper and it came with "lifetime replacement". OEM had no warranty at all.
Suit yourself.
  #31
okay Mr scientist it's up to you but thousands of posts in every SAAB site reported how Chinese knock off are unreliable at all, any other part in that car could be replaced by AM parts except THAT part. ask to anyone here.
https://www.saabcentral.com/forums/sh...irect+ignition
if you want to ship defective part even with warranty back and forth it still your concern.
you remember me when you still at 2 o clock in the middle of nowhere on the roadside.
  #32
My Saabs: 2001 9-5
Can I assume you make your living from OEM parts, or are you just a "my way is the only way" type guy?
Back off. I'm a big boy and it's not my first rodeo.
  #33
bob3000's Avatar
You might want to carry a spare DIC (even if it is an aftermarket one) to compliment the one you have because when it fails you could be stuck.
  #34
Old 12th August 2017
Mimmi's Avatar
Suit yourself.
No need for harsh language, if somebody really want to help you.
Your car, your decision, but do not come here and whine "Saab is crap etc".
Closed Thread
