$500 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > 9-5 Performance, Mods & Tuning
9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the 9-5
Old 1st December 2005
hambone575 hambone575 is offline
My Saabs: 9-5 Aero Wagon
Default $500
So I got approximately 500 bones and I want to upgrade my stereo. My center channel is no more. I took it out because the voice coil was blown. And it sounds like my passenger door panel speaker is not so hot. So I want to replace some speakers. The size of the ones on the dash are to small(not a standard size) something like 2 1/2 so I would need to make things bigger and i am a little nervous about that.. Also whats the deal with saab wiring its so simple like a phone jack or whatever. I can wire up a new speaker just need to be told how. Can someone just point to me what to get and I will get it, and then try to install. Thanks
2000 aero wagon, with tape deck in the factory stereo the center channel though when I took out said harmon kardon on the bottom of it... Just saying this to help you guys know what stereo i have..
Also is this going to sound any better with other speakers in there?
Or
Should I just go with an exhaust?
Or
Deliverypipe?
saabnc saabnc is offline
My Saabs: 1999 9-5 2.3 SE, BSR Stage 2
IMO, I care more about performace stuff than my stereo. If exhaust and delivery pipe are the two options you're considering, I'd go with exhaust, although neither will do a drastic performance change unless you have the software.
So, why not save up a few more bucks and upgrade the ECU?
Chris 9-5's Avatar
Chris 9-5 Chris 9-5 is offline
Saab Sage!
My Saabs: .
Forget the delivery and intake pipes!
Down pipe and race cat would really improve turbo spool up
I decline to grant to SAABCENTRAL.COM a non exclusive, royalty free, worldwide, perpetual license to reproduce, distribute, transmit, sublicense, create derivative works of, publicly display, publish and perform any materials and other information I submit to any public areas....
i want an aero's Avatar
i want an aero i want an aero is offline
My Saabs: 1998 95 2.3 lpt se nordic tuning
i agree with chris, far better and sounds great
bobsaab bobsaab is offline
My Saabs: 2k 9-5 Aero MapTun 4.2
Another agreement with Chris here...
Wow, yeah thats exactly what i was kinda leaning towards. I figure if i get the exhaust and down pipe it would sound better and maybe little boost in performance. My big thing is I drove an aero wagon with the bsr stage 1 and it wasnt really anything special. I mean I wanted the car to go VROOOOOOOOOOOOM . But it just when Vroom. And my aero goes Vrom... Well you get it. So anyways.. I guess the stereo doesnt matter too much if i will be wanting to listen to my pipes.
Whats going to be the overall price of the full exhaust? That is installed and everything? What options should I look at as far and downpipe and race cat/sport etc? (What about something like Finns ) SO SEXXY.. I dont know much about exhausts so anything would help. I know all the saab sites but doesnt mean too much just reading its a 3" etc. I guess it would need to pass inspection in Ma, for whatever that is worth.
Downpipe and cat are normally around 600-700 dollars. Then from the cat back its about 350. So for the full exhaust, you're looking over $1000.
Yeah ouch..... And pretty sure those numbers are not installed. Ok so I will try this again..... Forget everything.... for my stereo what speakers do I put in and just what I said in the begining. Forget I said delivery pipe etc... Thanks.. I am not in that high roller league yet... emphasis on yet
Well you said you already have Stage 1 software. If you add a catback exhaust, thats stage 2. No new software needed.
You can get the Remus cat back for around 350 dollars, VERY easy DIY installation
Old 2nd December 2005
Nah, sorry I just drove a car with a stage one. However I do not have a stage 1
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Are you sure?
Which tuner suggests this on an Aero?
robw's Avatar
robw robw is offline
My Saabs: '03 9-5 Aero manual
Just my 2 cents, but I would stick with the stock system. Sounds like you have the AS3 system - see here for more info:
http://www.mitt-eget.com/saab/faq.shtml
The stock speakers have unusual impedances and are designed to work with the stock amp, which is designed to work with the stock head unit. I think the AS3 system sounds quite nice and I'm a bit picky about audio. I believe that to get significant improvements in sound would require replacement of all of the system - head unit, amp, speakers, wiring, etc..
My opinion, get a new center speaker form a salvage yard and save your $$$$.
Originally Posted by Chris 9-5
Are you sure?
I believe the only difference between stage 1 and stage 2 BSR is the exhaust, and an air filter... isn't that correct?
RobWThanks, I was going to just ask if I could get a redo thread in order to get my questions figured out.
robw's Avatar
hambone,
No problem - you'll find that, although we may sometimes meander around a bit (I am as guilty (if not more!) as anyone else of this), we usually get to the point eventually.
