New Tech II - First Steps? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Tech II Workshop
Tech II Workshop For all discussions regarding the Tech II onboard diagnostics tool.
Old 28th May 2019
BobSaabit's Avatar
BobSaabit BobSaabit is offline
My Saabs: '03 9≥ 'vert; '01 9≥ 5d & parts car;
Default New Tech II - First Steps?
Just ordered a Tech II: http://www.chinacardiags.com/wholesa...l-package.html . Will be here in a couple days.
I'll be using it on OG 9-3's.
What are my first steps? Can I just plug in the card, hook up the cable to the OBD connector and start doing basic tweaks? Or do I need to setup some stuff (via PC?) before starting out?
Thx,
Old 28th May 2019
CJPeterborough CJPeterborough is offline
My Saabs: 9-5 Aero Wagon 2008;Aero Saloon 2001;
Very little on the OG 9-3 requires security access (or the CANDI!) so just plug in and go.Lots on the NG requires security access and PC hookup.
Fault trace in WIS is useful for troubelshooting codes.
Old 28th May 2019
BobSaabit's Avatar
I'll need to put the software on a PC to do that? I have the WIS... do I need TIS installed too?
Old 28th May 2019
Not really needed unless you intend to replace and flash an ECU or module and you are probably a long way from doing that at the moment.
Old 28th May 2019
BobSaabit's Avatar
Naw... I have still have T7 Suite and a combi adapter in a box waiting for those duties.
If itís decide to get a 9-3 SS will I have to get more involved?
Old 28th May 2019
Almost certainly
Old 29th May 2019
Riccird1 Riccird1 is offline
My Saabs: Saab 9-3 '01 2.0T
You will have to use the CANDI-adapter as a communication interface for the ng9-3.
To make ANY changes or alterations on the NG9-3 you'll need TIS on a PC + a serial port (DB-9) on your PC or a serial adapter. This will let you activate security access.
To only read and delete DTC's (fault codes) you can just straight up hook the tech2 up to the car with the CANDI-interface inbetween the car and the tech2
Old 29th May 2019
EdT EdT is offline
My Saabs: 1997 900S Coupť, 2003 9-5 Linear Wagon
It's also possible to update things other than the ECU, for example the ACC. I"m not sure exactly how many such modules there are on an OG9-3. (Maybe just ECU, TCU, and ACC based on my T7 9-5.)
HTML code is On
