Red or Black Direct Ignition Cassette (DIC) ? Read Here - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
Notices
9000 Workshop 9000 (1985-1998) Technical Forum
Old 24th February 2015
SaabKen's Avatar
SaabKen SaabKen is offline
My Saabs: '06 9³ 2.0T Combi, BCB Stg 2
Garage
Default Red or Black Direct Ignition Cassette (DIC) ? Read Here
http://www.saablink.net/forum/perfor...-9000/8421.htm
2006 9³ 2.0T SportCombi BCB Stg 2 | 2004 Subaru Outback H6 3.0 | 1993 9000 CSE (RIP)
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Garage
Threads specific to the 9000 and the red v. black DIC issue:
https://www.saabcentral.com/forums/sh...ight=thyristor
Saab Technical Service Bulletin explaining the difference between the T5 & T7 DIC/IDM and cautioning AGAINST using the incorrect version:
The DIC/IDM is generally not serviceable - it cannot be repaired. However, the DIC/IDM found on the Saab 9000 in model years 1987-1992, including the 91-92 9000 I, naturally aspirated 2.3L, which used a DIC but not T5.2, and the 91-92 9000T, 2.3L turbo, which used Direct Ignition with the old APC engine management, Hall effect crank sensor & external knock sensor can be fitted with individual replacement coils (Part No. 7589815) available via Saabsite.
If it is the internal electronics that have failed, nothing can be done to repair the unit. The thyristors (Triacs in the case of T7 DICs), capacitors and signal processors in ALL versions of the DIC are completely encased in the epoxy and it is a destructive process to expose them. So, there are no serviceable internal electronic parts for Trionic DICs for 9000, NG900, OG 9-3 and OG 9-5. In addition to the aforementioned replaceable coils for the eligible 9000 models, the plastic bottom (if it has cracked), the spring contacts within the boots (if any have gone missing or been hopelessly deformed) and the external harness to the DIC/IDM itself, can be serviced/replaced for DIC equipped 9000, NG900, OG9-3, and OG 9-5.
chengny's Avatar
chengny chengny is offline
My Saabs: 96 9K CSE, 97 9K CS, 96 9K CS, 94 9K CSE
X2 - I tried to get to the electronics one time. I saw the epoxy they are encased in, and quickly realized that it wasn't going to happen:
Garage
Yeah, it is not designed for service there.
Old 9th March 2016
kiwisaablover kiwisaablover is offline
My Saabs: 96 9000 Aero (gone :-(), 02 9-5 Aero
Garage
Default DI connector pin positions
May be a dumb question, but I'm trying a diagnostic for my 96 Aero (Red DI Cassette) and the instructions refer to pins 6 & 10 in the connector. Which ones are they? Can't find a diagram anywhere - mine has only 9 pins in it!
Mark
Saab History:1984 Black 900 5 spd turbo coupe,1991 Silver/grey 9000SE 2.3t auto,1994 Gold/silver 9000CSE 2.3t auto,1996 Silver 9000 Aero auto,1995 Green 9000 CS 2.3 5 spd parts car.
Old 9th March 2016
dmgb5's Avatar
dmgb5 dmgb5 is offline
dmgWarden
My Saabs: '89 900 T16Spg, '97 9000 Aero, '78 KZ650
Garage
The DI connector is a 10 pin connector of which 9 are pinned. The pins are labeled, either on the side or the top of the connector.
Pin #10 should be your power--thick red/grey wire. Pin #6 should be your earth--black wire.
Old 9th March 2016
Banman's Avatar
Banman Banman is offline
My Saabs: 91 900s turbo/ezk (sold) 97 9000 CSE
Just had mine apart--the corners of the connector have raised #'s. You should see the "6" and "10" clearly after a little cleaning. You might need a magnifying lens as well...
Banman
'91 16vT
'97 9000 CSE
'75 IH Scout
Old 12th March 2016
Garage
Thanks guys - I'll get back in to it later today. She just suddenly wouldn't start and I did the fuel pump a few months ago. I'll run through Ari's test sequence further but I think it may be the CPS - the tacho needle isn't "bouncing" which someone said indicates CPS - 310,000 KM (nearly 200,000 miles) on the clock and only recently a few little niggles like this. I buy my parts from eEuroparts in the US and normally takes only 2-3 days to get to New Zealand so hopefully I'll be up & running again this week. In the meantime luckily I have my 2004 9-5 Aero to drive, but something about my 9000 gives me more pleasure even though it's got a few less HP
Mark
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
For Sale: Black DIC direct ignition cassette '09 T7 Nele Parts for Sale/Wanted - North America 2 14th January 2014 07:41 PM
For Sale: Saab direct ignition cassette Black DIC from 2010 Nele Parts for Sale/Wanted - North America 3 28th December 2013 10:32 PM
For Sale: Black Direct Ignition Cassette (DIC) imola_red Parts for Sale/Wanted - North America 6 13th November 2012 01:23 PM
For Sale: T5 cams + Black Direct Ignition Cassette (DIC) imola_red Parts for Sale/Wanted - North America 4 19th December 2011 03:39 PM
For Sale: T7 (black) DIC (direct ignition cassette) DesmosDromos Parts for Sale/Wanted - North America 1 30th May 2011 12:04 PM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
