How To: Transmission Fluid Change on the Aisin Warner AWTF-80SC (06+ Aero Automatic) - Page 12 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Engine Oil, Lubricants & Fluids
Notices
Engine Oil, Lubricants & Fluids Discussions about engine oils and all automotive fluids
Old 9th November 2018
Phillie Chilly Phillie Chilly is offline
My Saabs: 2007 Saab 9-3 Aero
When I did mine the fill bolt was seized. I tried everything to get it off, but eventually I went to store got a big 24mm nut and quickly tacked that on top. Came off easily with that dab of heat and nut easily crank on. Also, Aisin Warner is a Toyota company. This transmission and variants of it were used all over (Ford, Buick, Toyota, etc.). I used a Titan ATF 4400 fluid which meant the spec of the original Saab fluid (AW-1). It's also made by Fuchs which has made other Saab transmission fluids as well. I never had issues after 60k and multiple changes on the stuff. It was about $12-16 a quart.
Old 15th December 2018
The Laminator's Avatar
The Laminator The Laminator is offline
My Saabs: 2007 9-3 Aero VTuner Stage 2
I get mine done every spring at George's Imports. It's the one thing I still just don't mess with myself. Hey cool that you are in the area CatsAndBrews! Stay in touch.
  #223
Old 1st January 2019
cloves cloves is offline
My Saabs: 2k 9-3 Convertible; 07 9-3 9440 V6 Aero
Thanks again for this tutorial and putting up the pdf as the photos are blank now.
I came across this video on youtube, same transmission and its the exact same procedure as the book (similar to yours) except they used the fill hole. It might be worth using some sort of penetration fluid on the fill hole especially if you are going to do multiple fills to try and get all the old fluid out. Big time saver. I was thinking about picking up an oil extractor and getting into it from the top fill hole but looking at the photos of the transmission online, not sure I could that hose deep enough into it to get the extraction hose all the way to the bottom.
Inside the WIS I also found instruction on the process but was most interesting was this diagram, which explains the leaving the small screw off until its started dripping then adding another 500ml of trans fluid.
Whoops forgot link to video (thanks swedepeed7):
AF40-6 / TF-80SC ATF How To Oil change
Name:	Saab 2007 WIS - Transmission Drain Plug.jpg
Give back to the community, if you post and/or fix something let the rest of us know.
  #224
swedespeed7's Avatar
swedespeed7 swedespeed7 is offline
My Saabs: 2008 9 Aero SS, 2011 9-4X Aero
Garage
Link to video? Also, you may want to edit your "My Saabs" to 9440, not 9400
Past SAABs: '93, '94, and '95 9000 Aeros, '01 Viggen, '09 2.0T SS
  #225
Old 11th March 2019
SAABenson's Avatar
SAABenson SAABenson is offline
My Saabs: 2008 9-3 Aero 2.8T
Great video. Very informative. Best one Ive seen yet.
  #226
Old 10th May 2019
tpdtopcop tpdtopcop is offline
My Saabs: 2006 Saab 9-3 Aero 2.8 Laser Red
Default Tranny Oil
going to be doing this with in next couple of weeks and really confused on which oil I should use? Have 06 9-3 Aero with 139,000 and I am sure the transmission oil has never been changed.
Is this okay to use
https://www.wpdusa.com/products/2655...ywords=JWS3324
https://www.napaonline.com/en/p/AOCATF0WS
  #227
Old 10th May 2019
Garage
Is this okay to use
[URL=https://www.wpdusa.com/products/26558/123941[/URL]
you could definitely try using the Aisin Warner WS fluid, but most of us have been using the OEM fluid. Just buy enough to get free shipping here:
https://www.esaabparts.com/saab/parts/93165147
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
Automatic Transmission Fluid Change DarthMaul 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 41 1st May 2019 08:16 PM
Automatic transmission fluid change vitkh 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 6th May 2013 08:50 AM
Automatic Transmission Fluid Change Adrian92 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 24 18th April 2013 12:18 AM
Automatic Transmission Fluid Change Edenite 9-5 Workshop 16 5th September 2010 01:49 PM
Automatic Transmission Fluid Change tonyiiiafl 9-5 Workshop 10 27th February 2008 11:11 AM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
