PCV Update Kit #6 Question - Page 2 - SaabCentral Forums
Old 11th June 2019
Doug's Avatar
Doug Doug is offline
My Saabs: '97 9000 Aero. '04 9-5 Aero estate
Get it re-mapped!
This guy is highly respected in the Saab community in the UK. Including me and my 9-5.
http://noobtune.co.uk
Apparently you can get 220 HP and 360 Nm!
Doug
Old 11th June 2019
Paragon Paragon is offline
My Saabs: 9-5 2.0t ARC Sport Wagon
Hi Doug,
I know about all the software mods, but it's not that easy. Remapping an 250,000 mile engine is not wise, especially with stock internals and cooling.
If I am to improve my 9-5, I would go with poly bushings, sport engine and transmission mounts and metal brake lines. Being able to corner and have better handling seems like a better mod overall.
  #23
Old 11th June 2019
bob3000's Avatar
bob3000 bob3000 is offline
My Saabs: 2000 9-5 AERO 5spd man MPS STG2
I would check the condition of the PCV hoses, if you pinch them and they feel mushy and stay stuck together in a pinched form when you release them then the rubber is breaking down and will cause sludge, if they are firm and bounce back from a pinch I'd just leave it as is.
  #24
Old 11th June 2019
I understand your reasoning, but isn't the number one advice if you have an engine that doesn't have the updated system, to get that update to prevent any sludge?
  #25
Old 11th June 2019
andybisnut andybisnut is offline
My Saabs: 2006 9-5 SportCombi 2.3T
I think you would have had engine failure a LONG time ago if you had sludge issues. Cars with sludge definitely don't make it to 250K!
But it's your call of course. If you wanna do PCV #6, go for it. We're all very opinionated on here.
  #26
Old 11th June 2019
Hi andybisnut,
I should give you more insight: after I got the 9-5, a weird whine started to appear when the car was cold, I suspected it was the sludge. Took it to a shop, to have the pan dropped and cleaned, they did that and also replaced all of the crank bearing, as they were worn. So clearly, the car at some point, had some issues with the oil. That's why I'm looking into the PCV update.
Side question. The car has some weird hissing noise, coming from the passage side of the engine, could that noise be generated by a worn idle pully?
  #27
Old 11th June 2019
Hi andybisnut,
Hmm. A hiss to me usually means large-ish vacuum leak. Mine was hissing once and it was because I forgot to plug the brake booster hose back in.
But it could be anything. If it were me I'd check for air leaks.
  #28
Old 11th June 2019
I know, but on the right side of the car? What hoses are on that side?
  #29
Old 12th June 2019
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: Hirsch fleet: 2*9-5 + 9-3
PVC hoses.
  #30
Old 12th June 2019
Then it's pretty much clear that I have to check the whole PCV system for leaks and bad hoses. A bad pully can also make that sound?
  #31
Old 4 Weeks Ago
swisssaabist's Avatar
swisssaabist swisssaabist is offline
My Saabs: 9-5 ARC estate 2002 2 t auto B205E
Originally Posted by hunterstein555 View Post
What year is your car? I don't recognize the '2.0t sportcombi' as a 9-5
On European market they have made 2.0lt sport combi like mine who was from 2002 also.
To All Sorry if my english isn't so good, Try to do my best to learn every day.
  #32
Old 4 Weeks Ago
The Combi term is just the European way of saying "Estate" or "Wagon".
  #33
Old 4 Weeks Ago
Originally Posted by andybisnut View Post
I don't think we got the 2.0 in the U.S. on the 9-5, but I definitely see other forum guys outside the U.S. with them. I wonder how it compares to the 2.3?
it drives with 35 less horses than the 2.3 just the lack of power you need to believe you're in a rocket specially when you accelerate for passing a new diesel HDI.
  #34
Old 4 Weeks Ago
Mariner Mariner is offline
My Saabs: 2006 SC #1 , 2006 SC #2
Hi Paragon,
Yes I'd suggest checking whole PCV system well. And try your best to isolate the "hissing noise" - a mechanic's stethoscope might help, but be careful around the serpentine belt.
Another trick is to remove the belt and run the engine for just a half minute or less to see whether the noise is related to the belt, tensioner, alternator, AC compressor, or pulleys.
Mariner
2006 9-5T SC #1; 2006 9-5T SC #2
