ground points? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 30th June 2006
saabkid37 saabkid37 is offline
My Saabs: 99 Viggen
Default ground points?
how many are there and where are they located? i only know of 2, the transmission one and the upper engine mount to head, how many others? i might as well cross the ground off the list of things that could be casuing my 02 sensor issues...
Old 30th June 2006
Stefano's Avatar
Stefano Stefano is offline
Saab Mad
My Saabs: 2 9ks,white '87T &'96 Silver Aero 2.0
I might be wrong but if your o2 sensor has 4 wires one of them is the ground, so if it's not snapped grond shouldn't be a problem. If it only has three, ground should be supplied by the wire close to the dogbone.
Old 30th June 2006
yaofeng's Avatar
yaofeng yaofeng is offline
My Saabs: '94 9kcs, 9kcde, '95 9kcse, all turbo
There are 16 to 17 ground points on the 9k. The description is in the wiring diagram. There is one online.
AIM:yaofeng4249
'94 cs, '94cde, '95cse, all turbo and 5 speed all gone,
4 bimmers now '95 525i, '94 540it/6, '01 540it, '03 325i
Old 30th June 2006
My Saabs: 99 Viggen
its a 4 wire, but ive been getting p0130 (faulty o2 sensor bank one sensor one) no matter what i do. ive tried 2 different ecus, new sensors, checked all the wiring...next up is putting stock exhaust back on and clening the grounds.
Old 2nd July 2006
sleeper9kt's Avatar
sleeper9kt sleeper9kt is offline
remove your battery, you will see a whole bunch of little black wires leading to a ground point behind the battery box on the frame. There are also some other areas down behind the headlights and scattered in various locations. I remember finding at least 3 major grounding points when removing the motor and wire harness from the '91 9000 (this is not including the grounding strap on the dog-bone mount or the ground to the trans).
2001 325XiT - slow / 1995 9000 Aero - 426whp /
1999 9-3 - stage 3 / 1973 99LE
1994 900 V6 - Team Cougar Bait - 24 Hours of Lemons
Old 2nd July 2006
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
My Saabs: Wife's 9-3
... ive been getting p0130 (faulty o2 sensor bank one sensor one) no matter what i do
Look for vacuum leaks. I suggest spraying carb cleaner around suspected areas.
Old 8th June 2019
Dvo.jacob's Avatar
Dvo.jacob Dvo.jacob is offline
Where is there a ground point for an amplifier in the trunk of a 9-3 sportcombi. Ive tried almost everything and the only one that works is the truck latch
