2007+ dash swap into 2003 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan, Cabrio ('04+), Combi & 9-3X, 2003-2012 > 9-3 Sedan, Convertible('04+)/Combi & 9-3X Tuning/Modifications - 1.9TiD-TTiD/2.0t/2.0T ONLY
9-3 Sedan, Convertible('04+)/Combi & 9-3X Tuning/Modifications - 1.9TiD-TTiD/2.0t/2.0T ONLY Covers Tuning & all Performance modifications specific to 1.9TiD-TTiD/2.0t/2.0T ONLY
Old 30th September 2015
tour96se tour96se is offline
My Saabs: 1997 talladega convertible
Default 2007+ dash swap into 2003
Got bored and did this in about 2 hours, also converted to the newer style acc unit, in the process of trying to get the gauge cluster to play nicely with the acc unit, not much succes though. most be a voltage difference between the 2007+ and older systems. the acc backlight flashes with the newer cluster in and married, tech 2 shows voltage increase and drops that coincide with the flicker as if someone is changing the dimmer settings.
I also am using the newer headunit for now. and i did anniversary interior swap at the same time.
Diggs's Avatar
Diggs Diggs is online now
My Saabs: 2003 9³SS Linear; 2015 VW GTI
Thumbs up
Wow, nice job.
The answer is almost always....Tech2.
You can either buy one or be a slave to your mechanic/dealer when you need repairs. Your choice.
Never have less than TWO working key fobs.
Djfremen's Avatar
Djfremen Djfremen is offline
My Saabs: TECH2- 2x '04 9-3 Arc - 1x '07 9-3 Arc
UnREAL! I always thought this could be done. Please outline the procedure - especially the difficulties... What about MOST / fibre?
i'll make a full pinout when i know for sure if i can/cant get the sid control panel and cluster from the 2007 to work with my car. as of now i can't. I have the pinout for the acc swap, thats pretty simple really.
its a lot of WIS reading and searching right now, what a horrible layout on that program, its maddening.
Old 1st October 2015
emjohn4 emjohn4 is offline
My Saabs: '03 93 Linear 2.0t
Tell me tell me tell me tell me tell me!!!
100 internet cookies for you if you do.
And a lighter wallet for me if you do.
But....tell me tell me tell me tell me tell me!!!
Old 2nd October 2015
what is it you want me to tell you? haha
the dash itself is nearly a direct swap, you will need to drill two new mounting holes above the cup holder. The center stack on the dash was changed, really, it was all shifted down to make space for the gm sized stereo. So two of the four mounting points are different then the 03-07, but thats a 20 second fix with a drill. You'll need the center vent, sid control panel(dimmer switch in the 07+ really), cupholder trim, and upper gauge/stereo shroud. The side vents,ashtray/or cubby pocket,glove box, and climate control unit(i'll get to that) are interchangeable. The cc unit from the 03-06 doesn't fit 100%, the mcc can be pushed in and will fit fine, the acc unit has led display that doesn't like to be squeezed , ideally you need to trim a little off the sides of the cc units face plate, or if you have acc you can convert to the 07+ with just a simple repinning of the 03-06 harness. Sorry mcc guys, trimming the face plate is the best advice i can give you, and in all honesty, it allows you to use the 07+ gauge cluster, which is a bonus because 1) it looks better 2) you retain your SID info.
As far as head unit, that's your choice, i had already wired in a 4 channel amp when i was using the old icm2, so this allowed me to use the factory head unit with just using power and ground wires from the old icm harness and running my own speaker wire to a line out converter to the amp and speakers. Or you could run audio cords to the amp if you are planning on a aftermarket headunit.
Old 3rd October 2015
Do you have any info on how to repin the manual climate control for the swap?
We looked into it bc I was going to switch to mcc. Most of the components besides the blower motor are different
Old 23rd March 2016
Ronson Ronson is offline
My Saabs: Saab 9-3 2.2 TiD Aero V6 look
Can you please explain me how you did the repinning of the 03-06 acc harness? Maybe a step by step. Thanks!
Old 13th September 2018
gavin.thompson gavin.thompson is offline
My Saabs: None, Z20NET VECTRA
Did anything ever get accomplished with this?
Old 22nd December 2018
Steven_FJX's Avatar
Steven_FJX Steven_FJX is offline
My Saabs: 2006 Saab 9-3 Aero
Default Well done!
Lot's of forums say you cannot do this, especially the dash. Myself I am in the process of swapping all the old grey interior to black interior.
Old 27th December 2018
KaMiKaZi_t0M's Avatar
KaMiKaZi_t0M KaMiKaZi_t0M is offline
#1 Super Guy!
My Saabs: 92 C900T vert, 95 9K Stg3+, NG900 HX35
I've never married a facelift cluster to an older 9-3, but there are some serious BUS differences electrically and communication wise. The I BUS is most likely going to have none of this without a full replacement of nearly all modules on P and I BUS with security access and VIN continuity. Looks cool though!
Old 12th April 2019
japakos japakos is offline
My Saabs: 06 9-3 Vert, 03 9-3 Aero
Excellent job, I am in the process of swapping the newest acc unit in my 06 Saab.
Is it only repining you need? Will it work without flashing LEDs and stuff?
9-3 2004 dash to 9-3 2007 new style dash??? marctbates 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 12 11th July 2015 08:15 PM
2003 9-3ss Aero Dash lights stay on- ignition switch swap? FrontBackSide2Side 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 25th February 2015 06:00 PM
2007 9-3 2.0l engine swap ? zrxman 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 13th June 2014 08:29 PM
Is is possible to swap parts on a 2007 HID Headlight to a 2003 halogen marcus73 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 22nd August 2013 08:25 PM
