*** Frequently Asked Questions *** and minor maintenance help. - SaabCentral Forums
Closed Thread
Old 25th December 2007
Chris 9-5's Avatar
Chris 9-5 Chris 9-5 is offline
Saab Sage!
My Saabs: .
Default *** Frequently Asked Questions *** and minor maintenance help.
General Topics:
Common Saab Acronyms
OBD II Fault Codes
Purchasing Advice: Work in Progress
Technical Service Bulletins - Saab 9-5
VIN Decoder :
Saab Spares suppliers mail order
UK Direct Ignition "Service Campaign".
The Detailing Thread!
Understanding Oil Specifications
Find your Lost Boost
Lets build a B234/235 Hybrid engine
Service Threads:
Time for Service Reset
2004 9-5 Limp home mode reset
9-5 Service Schedule
Cabin/Pollen Filter Replace
Cabin Filter Replacement
Fuel filter replacement instructions
Oil Change Instructions
Oil Change...how to do.
AT F - How to Change
Sparkplug Changing Guide
PCV modification - please read!
Maintenance Threads:
Window Roller Replacement
Window Roller Repair (with pics)
Heater Bypass Valve Replacement
Lets Replace the Coolant Temp Sensor
Lets Replace the Thermostat
Fuel Pump replacement
V6 oil cooler replacement
Latest PCV fix
Service Theft Alarm.....the fix.
Throttle Body Replacement
Key Fob Battery Replacement
Location of V6 Thermostat and fix
Crankshaft Position Sensor - Stalling
ABS Module Fix
Heater Bypass Valve
Coolent Bypass Valve
Heated Seat Switch Bulbs
Front Wheel Bearing 02-
Replacing boot /trunk lid shocks
Replacing Brake Booster / Servo Unit
Replace Cabin Fan
Trunk / Boot Wire Harness Repair
DIY Replacement of Turbo
Fixing the Neutral Position Sensor Switch
Remove Centre Console Trim
Steering Column Spline Lube
Brakes:
Performance Brakes
Brake Pads and Rotors Change
Rear Brake Discs / Rotors
Suspension:
Shox and springs installation
Sludge & Related Threads
NEWS - Saab offers 8 year warranty on engines
Oil Sludge - Definative Guide
Guide to dropping+cleaning sump/strainer
Sump drop procedure inc pictures
Engine Sludge, symptoms and how to avoid.
Display Repair Guides
A/C Panel Pixel fix
Sid Pixel fix
Stereo / Electrical System:
Connecting an MP3 Player to the AS1 Stereo
Replacing Switch Backlight Bulbs for 49p
Adding aftermarket Double Din
Pioneer Avic-f700 bt instal
ACC System:
ACC Fault Finding
Dreaded 08 A/C fault code repair
Performance Threads:
Tuning The 9-5
Body Kit suppliers
King Cobra Fitment
Garret G17 swap to TD04 Turbo
Checking Base Boost
Open Air Intake
Front Mount Intercooler
Very Helpful Sites with Fixes :
FixMySaab
I decline to grant to SAABCENTRAL.COM a non exclusive, royalty free, worldwide, perpetual license to reproduce, distribute, transmit, sublicense, create derivative works of, publicly display, publish and perform any materials and other information I submit to any public areas....
Quick reply to this message
Closed Thread
