Fuel Distributor Woes - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 99 & 90 > 99 & 90 Workshop
99 & 90 Workshop 99 & 90 Technical Forum
Old 29th September 2018
Mitchapalooza848's Avatar
Mitchapalooza848 Mitchapalooza848 is offline
My Saabs: 1978 Saab 99 EMS
Default Fuel Distributor Woes
Picked up a 78 Saab 99 EMS. Going through the fuel system cause it’s been sitting for a long time. I’m kinda new to these injected cars.
Fuel pump is working with good pressure. Cleaned all the lines and filters. Tested injectors out of car and they all have good atomization.
What I don’t quite understand is the distributor function or not function pertaining to the air flow sensor (round flap). If the fuel pump is running but the air flow sensor is in the down position, should the injectors be atomizing fuel?
In my case no matter the position they seem to squirt lots of fuel. I think they might just be flooding the engine.
On top of this I need to make sure the ignition system is also working properly. I’m beat tonight but I’ll test tomorrow if it’s sparking correctly.
Old 6th July 2019
pzachary pzachary is offline
My Saabs: c900n/a, '78 99turbo
I've been off the forum for a while, did you get this sorted?
Easy test for the CIS head:
Remove the rubber elbow coming out of the air-cleaner assembly.
Attach a bit of tape to the air-measuring plate you can lift it with.
remove injectors and stick them in bottles or something to catch fuel.
Turn the fuel pump on (bypass the fuel relay).
With the plate completely down you should have no fuel flow.
Lifting the plate and you should have progressively more flow.
If you are flowing fuel at all plate positions, sounds like the plunger might be stuck.
FWIW, the later CIS heads off the 8-valve 900s work great in the 99 and are easier to adjust to run well.
Replacement for Plastic Fuel Line from Fuel Distributor to Fuel Injector Cgiff9 C900 Workshop 13 15th November 2014 12:40 PM
distributor woes powitte NG900 & OG9-3 Workshop 5 16th October 2010 08:40 AM
Fuel line order on CIS fuel distributor thehunch C900 Workshop 2 13th January 2006 06:31 AM
Distributor Cap Woes slypperypete C900 Workshop 3 7th February 2005 07:39 PM
8v - replacing fuel pressure regulator / fuel distributor jim galbraith C900 Workshop 6 13th February 2004 06:34 AM
