Brake system flushing/bleeding with ABS - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Workshop
C900 Workshop Classic 900 (1979-1993 & '94 Convertible) Technical Forum.
Old 2 Days Ago
c900's Avatar
c900 c900 is offline
My Saabs: C900 x 3 and 9000 x 1
Default Brake system flushing/bleeding with ABS
Flushing brake system on my 2.1 sedan today with nice Aussie winter conditions (sunny, about 15 C outside) and no shift at work today.
Used my big oil syringe to get as much of the old fluid out of the reservoir as possible before starting the job proper. Took about 800 ml new fluid to fill the reservoir after the syringing.
I've been using my Motive Products power bleeder to assist the flush/bleed process. I followed the book procedure and bled both front lines first (as car has ABS), then used the ABS pump with 'block-o-wood' keeping pedal depressed to do the back lines.
Interestingly, the power bleeder doesn't seem to do much when bleeding the rear lines after the ABS pump stops and I switch off the ignition. Plenty of fluid flow with a bleeder cracked (must be due to the ABS pump pressurising things) though.
Seems to be ok. Doing clutch last.
I'm used to doing brake system flushes on c900's without ABS (or manual boxes), although my 9k with manual box has ABS and I know the brakes were flushed/bled find on that using a similar process to what I described above.
Craig Dewick - Somewhere in Oz -
Flux Capacitor Engineer at Mr Fusion - C900 x 3 + 1 x 9000 - RIP Moose.Parts
Old 2 Days Ago
jvanabra jvanabra is online now
My Saabs: LOTS. :)
Since the Teves system doesn't have a booster, the pump ends up being between the reservoir and the caliper, so a regular pressure bleeder doesn't work like normal. That's why you use the system to "self bleed."
