17ís for performance or 18ís for looks? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Wheels & Tires
Wheels & Tires Technical discussions about wheels fitment & tire specifications and reviews, independent of car model and year. Sponsored by Discount Tire
Old 21st September 2015
jza80 jza80 is offline
My Saabs: 2011 9-3 Aero SS
Default 17ís for performance or 18ís for looks?
So I’m thinking about some new wheels for the 2008 Aero I just bought. This particular car came with ALU59 wheels instead of the more typical ALU71’s, the original owner had them changed when the car was bought new.
I kind of like the looks of the ALU59’s but both right side wheels have pretty bad curb rash and the car is still on the original tires (car has only 21K miles, but the tires are from 2007). So at minimum I need either replace/refinish the 2 curbed wheels and get some new tires, OR replace the whole setup with some 18’s. If I do that, I am thinking about a set of ALU73’s to maintain an OE style look with some 235/45R18's.
On the one hand, the 17” wheel/tire package is probably at least 5 pounds lighter than an equivalent 18” setup so the suspension dynamics are probably better with the 17's. But the 18’s would look better. Any thoughts on this dilemma? I’m just wondering what the hit will be from a suspension harshness and handling point of view to jump up to the larger wheel and tire size. I know that TX wheels were 18”, but I don’t know the weight of the TX wheels relative to a set of 17’s or the ALU73’s.
Opinions/first hand experience are very welcome!
2011 9-3 Aero 5AT
2015 Chevrolet SS Sedan 6MT
2010 Suzuki Grand Vitara 4WD
1995 Mazda RX7 R2
Old 22nd September 2015
Matt761 Matt761 is offline
My Saabs: 2000 9-3 se
Well it's not all wheel weight. The eighteens will have a shorter sidewall which will give you less sidewall flex making it better for corners. But I'm not sure what the best balance is for your car.
2000 black saab 9-3 se manual
Alfisti Alfisti is offline
My Saabs: 9-3 Sportcombi 2008
Your problem is that you are retaining the same tyre width and sidewall height, so add the larger wheel and you're gonna REALLY fill the guards, maybe too much with rubbing etc.
Thanks for the replies!
My thought was to stay with OEM sizing, I believe the TX uses 235/45 18. If I went with 235/40 18 that just about matches the diameter of the existing but the ride harshness will likely worsen.
2011 9-3 Aero 5AT
1995 Mazda RX7 R2
There's no free lunch here, you will struggle by just going up a size without reducing the sidewall.
Go here http://www.1010tires.com/Tools/Tire-Size-Calculator
That puts your circumference change at 4%, rule of thumb is to stay within 3% or your speedo and ABS etc start to get confused.
You can probably get away with it but make sure it fits.
Thanks, I figured that if I went to 18's then I would change the tire size in Tech 2. I know that there are tradeoffs, I have upsized and downsized wheels in other cars. What I was curious about was how the 9-3 responded to a heavier wheel and tire combo, was there noticeable change to suspension dynamics and to a lesser extent vehicle acceleration.
Probably it is okay since SAAB offered the 18" size with 235/45 for the 9-3 in other markets and for the TX in the US. Maybe I am overthinking it...
2011 9-3 Aero 5AT
1995 Mazda RX7 R2
SaabKen's Avatar
SaabKen SaabKen is offline
My Saabs: '06 9≥ 2.0T Combi, BCB Stg 2
Garage
Does one really have to use Tech 2 to change the wheel/tire sizes in the ECU (or whatever else computers need the info) if the size discrepancies are < 3% from stock size ?
Also, jza80 ..... that 1010tires tire size calculator provides you all the different popular brands and models of tires available at each of the up-/down-sizing ....... useful to have and plan your purchase based on the options available at each size.
2006 9≥ 2.0T SportCombi BCB Stg 2 | 2004 Subaru Outback H6 3.0 | 1993 9000 CSE (RIP)
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
Probably not, but I have a Tech 2 so it would be something that I can easily do. In fact, the car is about 2-3% off right now (45MPH indicated is about ~43MPH on radar) so I am going to adjust it whichever way I go.
2011 9-3 Aero 5AT
1995 Mazda RX7 R2
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
Performance upgrade downgraded my performance! PlumLoopy C900 Performance, Mods & Tuning 52 24th January 2016 07:40 PM
RSS Feed Chicago 2011: Hirsch Performance Saab 9-3 adds some Swedish style, performance RSS Bot SAAB Corporate News 9 11th March 2011 01:58 PM
Performance manifold or headers for b-engine 1978 99L. Any other performance parts? AndrewSaab 99 & 90 Workshop 10 8th April 2009 05:03 AM
do high performance spark plugs add power/performance? virgbeachinmate NG900 & OG9-3 Performance, Mods & Tuning 10 23rd September 2003 04:11 AM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
